长沙鹏翔-声发射传感器-美国物理声学公司PAC
查看3921 | 回复1 | 2013-9-3 09:49:24 | 显示全部楼层 |阅读模式
美国物理声学公司PAC声发射传感器一览表的用途和特点:
型号
基本参数
A3
30KHZRES.,ACCEL.,MICRODOT, SINGLE-ENDED
AGM-WC-0
EMBEDDEDCOOLANTFITTING SENSOR WITH 4 FEET CABLE WITH 0 DEGREEWATERPATH
AGM-WC-90
EMBEDDEDCOOLANTFITTING SENSOR WITH 4 FEET CABLE WITH 90 DEGREEWATERPATH
AM2
20KHzairborne sensor
AM4
40KHzairborne sensor
AM2I
20KHzintegral preamplifier 40 dB gain airborne sensor
AM4I
40 KHzintegralpreamplifier 40 dB gain airborne sensor
CH6I
60 kHzResonancefreq., 40 dB integrated preamp
CH15I
150 kHzResonancefreq., 40 dB integrated preamplifier with AST
CH30I
300 kHzResonancefreq., 40 dB integrated preamp
D9202B
SENSOR,650KHZ,DIFF, W/INT CABLE
D9203B
SENSOR,175KHZ,DIFF, W/INT CABL
D9203C
SENSOR,175KHZ,DIFF, W/INT CABLE
D9203-IS
SENSOR,175KHZ,DIFF, I.S.
D9204
SENSOR, W/B,DIFF,W/INT CABLE
D9215
Hightemperature(1000 F) differential sensor with 2 feet hard line cableand 23feet soft line cable (See S9215-HLC and S9215-SLC in the"Cable"sheet for different lengthes of the hardline and softlinecable)
D9215A-LPME
D9215A-LPME Radiation resistantandhigh temperature sensor with one meter hardline cable and onemeterTefzel cable.
D9215-EPA-Nuclear
HIGH TEMP.1000FDIFFW/2'HD&23'SFT, EPA Nuclear Special
D9235
HIGHSENS.,260CDIFF. DE W/INT.CABL
D9240
UNIDIRECTIONALSENSOR W/DIFF SIDE C
D9241A
SENSOR, DIFF,30KHZW/CABLE
D9241-IS
SENSOR-LOWFREQ.INTR.SAFE/FLUID LE
DT15I
INTEGRAL SENSOR, 150KHZ(HF)40DB
DT6I
SENSOR,AST, 60KHZ, S-E,W-PREAMP
DT-9202B
SENSOR,450 KHZ (HF)
HD15
SENSOR,UMINIW/MOLEXCONN
HD15SS
ULTRA MINISENSOR150KHZ STAINLESS
HD2-WD
2MHZ HIGHFREQ.WIDEBAND SENSOR
HD30SS
SENSOR, MINI,SE,W/INTEGRAL TOP CA
HD50
SENSOR,UMINI,S-E,W/INTTOP 7" WHT
HD50SS
MINISTAINLESSSTEEL  SE W/INTRG CA
HF-15I
SENSOR,150KHZINTEGRAL,HIGH FREQUE
ISR-0.45
Intrinsicallysafe7.5 KHz sensor with 2 meter cable
ISR-1.5
Intrinsicallysafe15 KHz sensor with 2 meter cable
ISR-3
Intrinsicallysafe30 KHz sensor with 2 meter cable
ISR-6
Intrinsicallysafe60 KHz sensor with 2 meter cable
ISR-15
Intrinsicallysafe150 KHz sensor with 2 meter cable
ISR-30
Intrinsicallysafe300 KHz sensor with 2 meter cable
ISR-50
Intrinsicallysafe500 KHz sensor with 2 meter cable
IS-WD
Intrinsicallysafewideband sensor with 2 meter cable
IS-9203B
Singleended Intrinsically safehigh frequency sensor with 1 meter cableto be used with ValveSqueak
ISD-9203B
Intrinsicallysafehigh frequency sensor with 2 meter cable
ISPK3I
IntrinsicallsafeLow Power Sensor, 30 kHz with Integral Preamplifier, AST andSMAConnector to be connected to 1281 connected through1234-4001-xxxcable where xxx is the cable length up to 100meters.
ISPK6I
IntrinsicallsafeLow Power Sensor, 60 kHz with Integral Preamplifier, AST andSMAConnector to be connected to 1281 connected through1234-4001-xxx cable where xxx is the cable length up to100meters.
ISPK15I
IntrinsicallsafeLow Power Sensor, 150 kHz with Integral Preamplifier, AST andSMAConnector to be connected to 1281 connected through1234-4001-xxxcable where xxx is the cable length up to 100meters.
ISPK30I
IntrinsicallsafeLow Power Sensor, 300 kHz with Integral Preamplifier, AST andSMAConnector to be connected to 1281 connected through1234-4001-xxxcable where xxx is the cable length up to 100meters.
ISPKWI
IntrinsicallsafeLow Power Sensor, wideband (100 – 1000 kHz) withIntegralPreamplifier, AST and SMA Connector to be connected to1281connected through 1234-4001-xxx cable where xxx is the cablelengthup to 100 meters.
ISPK3I-UC
Underwater 30 KHz intrinsicallsafelow power integral preamplifier sensor with AST and BNCConnectorto be connected to 1281 through Underwater cable. Specifycablelength in meters.
ISPK6I-UC
Underwater 60 KHz intrinsicallsafelow power integral preamplifier sensor with AST and BNCConnector to be connected to 1281 through underwatercable. Specify cable length in meters.
ISPK15I-UC
Underwater 150 KHzintrinsicallsafe low power integral preamplifier sensor with ASTand BNCConnector to be connected to 1281 through underwater cable.Specifycable length in meters.
ISPK30I-UC
Underwater 300 KHzintrinsicallsafe low power integral preamplifier sensor with ASTand BNCConnector to be connected to 1281 through underwater cable.Specifycable length in meters.
ISPKWI-UC
Underwater widebandintrinsicallsafe low power integral preamplifier sensor with ASTand BNCConnector to be connected to 1281 throughunderwatercable.   Specify cable length inmeters.
LNI-150
150KHzlow noise integral preamplifier differential sensor
MICRO30/C
300KHZRES.,MINIATURE SE W/1232-1
MICRO-100
SENSOR, MINI,S-E,1MHZ
MICRO100D
SENSOR,MINIATURE,DIFF.1000KHZ W/1M
MICRO-100D
SENSOR, MINI,DIFFW/INT CABLE
MICRO100DS
SENSOR,1000KHZW/14"FLEXI CABLE LEA
MICRO100S
SENSOR,MINIATURE,SE,1000KHZ W/1M CA
MICRO-200-HF
SENSOR,MINI2.5MHZBNC W/12" CABLE
MICRO-30
300KHZRES.,MINIATURE, SE
MICRO-30D
300KHZRES.,MINIATURE DIFF. W/1M CA
MICRO-30S
300KHZRES.,W/1MINTEGRAL SE CABLE
MICRO-50
SENSOR, MINI,S-E,500KHZ
MICRO-50D
SENSOR, MINI,DIFF,500KHZ, W/CAB
MICRO-50S
SENSOR, MINI,S-E,500KHZ, W/CAB
MICRO-80
SENSOR,MINI,SE,800KHZ
MICRO80/C
MINI SENSOR,SE800KHZ W/1232-1 CAB
MICRO-80D
800KHZRES.,MINIATURE DIFF. W/1M C
MICRO80DS
SENSOR,MINI,800KHZ,DIFF.W/1M FLEXI
MICRO-80S
SENSOR, MINI,SE,W/INT CABLE
MINI-30S
300KHZ,INTEGRALCABLE,GLUEABLE SEN
NANO-30
300KHZRES.INDUST.MINI SENSOR W/1M
PICO
ULTRA-MINI WBSENSORW/1M FLEXI CAB
PICO-HF1.2
HIGHFREQ.PICOSENSOR W/1.2MHZ
PICO-HF1.5
SENSOR, UMINI,S-E,W/INT CABLE
PK3I
Low Power Sensor,30kHz with Integral Preamp and SMA Connector for Pocket AE&SensorHighway
PK6I
Low Power Sensor,60kHz with Integral Preamp and SMA Connector for Pocket AE&SensorHighway
PK15I
Low PowerSensor,150 kHz with Integral Preamp and SMA Connector for PocketAE&Sensor Highway
PK30I
Low PowerSensor,300 kHz with Integral Preamp and SMA Connector for PocketAE&Sensor Highway
PKWI
Low PowerSensor,wideband (100 – 1000 kHz) with Integral Preamplifier andSMAConnector for Pocket AE & Sensor Highway
R.45
SENSOR, LOWFREQ.7.3KHZ  BNC SIDE
R.45I
SENSOR,AST,LOWFREQUENCY W/INTREGA
R0.45I-ISC-15
4.5KHzINTRINSICALLY SAFE W/15M SIDE MOUNTING TRIAXIAL (YELLOW) CABLE,SETERMINATION
R.45IUC-5
4.5 KHz 200PSIepoxy coated under water sensor with integral preamplifier and5meter cable
R.45UC
4.5 KHZSEWATERPROOF, COATED SENSOR with 2 meter integral cable
R1.5
SENSOR,15KHZ
R1.5IAST
SENSOR,INTEGRALPREAMP, 15KHZ, AST
R1.5I-ISC-15
15 KHzINTRINSICALLYSAFE W/15M SIDE MOUNTING TRIAXIAL CABLE (YELLOW),SETERMINATION
R15/C
150KHZ SENSORRES.,SE W/1232-1 CAB
R15/S
SENSOR,150KHZ,RESONANT W/INTEGRAL
R15/S-LT
SENSOR,150KHZ,2MLOW TEMP CABLE
R15A
SENSOR,150KHZ W/SMA CONN -ALPHA S
R15D
150KHZRES.,DIFF.W/1M CABLE
R15I-AST
SENSOR, AST,150KHZSE W/INTEGRAL P
R15IC-AST
SENSOR,150KHzintegral preamplifier sensor with 40 dB gain, AST, coatedcavity,BNC connector and 15 meter cable
R15I-LP-AST
Coated,weather resistant, lowpower AE sensor for outdoor monitoring withauto sensor testfunction, 40 dB integral preamplifier and 25 meterRG-58A/Ucable
R15I-P
SENSOR,PULSER,150KHZ
R15IS
R15SENSOR,150KHZ,RES.INTRINSICALLY
R15I-SC-AST
SENSOR, R15IASTSIDE CABLE W/PREAM
R15I-T.C.-AST
SENSOR,AST,150KHZW/PREAMP, TCAB
R15I-TOPCON-AST
SENSOR, AST,150KHZ,PREAMP, TCONN
R15IU-5
150 KHzdoublecavity underwater sensor for nuclear application withintegralpreamplifier and 5 meter cable
R15IUC-5
150 KHz 200PSIepoxy coated under water sensor with integral preamplifier and5meter cable
R15IU/HP
HIGHPRESSUREUNDERWATER SENSOR
R15IU-AST
SENSOR, 150KHZ,U/W,INT.PREAMP/AST
R15-L/T
SENSOR, 150KHZ,LOWTEMP, S-3
R15-LPG
SENSOR, 150KHZ,S-E,DIR BURIAL
R15UG
150KHZunderground/water sensor with 2 meterside connectorcable
R15UG-TC
150KHZunderground/water sensor with 2 meter topconnectorcable
R3a
30KHzAlpha series sensor with SMA connector
R30A
SENSOR, 300KHZW/SMACONN- ALPHA SE
R30D
SENSOR,300KHZ,DIFF, INTEGRAL
R30I-AST
SENSOR,AST,300KHZ,SE W/INTEGRAL PRE
R30I-T.C.-AST
SENSOR,AST,300KHZTOP CABLE,INTEGRA
R30S
SENSOR, S-E,300KHZ,W/CABLE
R3I-AST
SENSOR, AST,30KHZ,INTEGRAL PREAMP
R3IC-AST
SENSOR,30KHzintegral preamplifier sensor with 40 dB gain, AST, coatedcavity,BNC connector and 15 meter cable
R3I-UC-30
UNDERWATERR3ISENSOR W/ 30M CABLE
R3IUC-5
30 KHz 200 PSIepoxycoated under water sensor with integral preamplifier and 5metercable
R30UG
300KHZunderground/water sensor with 2 meterside connectorcable
R30UG-TC
300KHZunderground/water sensor with 2 meter topconnectorcable
R50A
SESNOR, 500KHZW/SMACONN- ALPHA SE
R50D
500KHZRES.,DIFF.W/1M CABLE
R50I-AST
SENSOR, AST,500KHZ,INTEGRAL PREAMP
R50IUC-5
500 KHz 200PSIepoxy coated under water sensor with integral preamplifier and5meter cable
R50LT
LOW TEMP.SENSORW/1.2M INTEG.CABLE
R50S
SENSOR, S-E,500KHZ,W/CABLE
R50UG
500KHZunderground/water sensorwith 2 meter side connectorcable
R6
60KHZRES.,MICRODOT,SE
R6A
SENSOR, 60KHZW/SMACONN - ALPHA SE
R6D
SENSOR,60KHZ,DIFF.W/INTEGRAL 1M C
R6I-AST
SENSOR,AST,60KHZ,SE,W/INTEGRAL PREA
R6IC-AST
SENSOR,60KHzintegral preamplifier sensor with 40 dB gain, AST, coatedcavity,BNC connector and 15 meter cable
R6-IS
60KHZINTRINSICALLYSAFE SENSOR
R6I-SC-AST
60KHzintegral preamplifier sensor with a side cable andBNCconnector
R6I-T.C.
SENSOR,AST, 60KHZ, W/PREAMP & TOP
R6I-TOP-CON
SENSOR, AST,60KHZ,W/PREAMP & TOP
R6IU
60KHZRES.UNDERWATERSENSOR W/5M CA
R6IUC-5
60 KHz 200 PSIepoxycoated under water sensor with integral preamplifier and 5metercable
R6S
SENSOR, 60KHZ,S.E.,W/INT CAB
R6S-3
SENSOR, 60KHZ,S.E.,WITH 3 METER INT CAB
R6U
SENSOR,60KHZ,UNDERWATER/W 1M U/W CA
R6UC
60KHZ SEWATERPROOF,COATED SENSOR-
R80a
800 kHzResonancefreq., SE sensor, SMA connector
R80D
800KHZRES.,DIFF.SENSOR W/1M CABLE
R80S
SENSOR,S-E,800KHZ,W/CABLE
RS30
Rollingsensor
S9208
BROADBAND,SESENSOR
S9208/C
SENSOR,BROADBANDDISPLACEMENT W/CA
S9215
Hightemperature(1000 F) single-ended sensor with 2 feet hard line cableand 23feet soft line cable (See S9215-HLC and S9215-SLC in the"Cable"sheet for different lengthes of the hardline and softlinecable)
S9215-20
HIGH TEMPSENSORW/5' HARDLINE CABL
S9220
SENSOR,125KHZ,MINI, W/INCAB
S9223
45KHZ HIGHSENS.MINI SENSOR
S9224
SENSOR,775KHZ,MINI, SIDECONN
S9225
250KHZMICROMINISENSOR W/INTGRL. C
SENSOR/BOX
BOX WITH FOAM FOR16SENSORS
SH10
100KHzShear wave AE sensor
SH10I
100KHzshear wave AE sensor with 40 dB integral preamplifier
SM40
400KHzindustrial sensor with one meter metal skin cable andBNCconnector
UT1000
BROADBAND,ULTRASONIC BACKED SENSOR
VS9203IS
Singleended Intrinsically safehigh frequency sensor embedded inwaveguide and to be used withValve Squeak
WD
WIDEBANDDIFF.SENSORW/1M INTEGRAL
WDI-AST
WIDE BANDINTEGRAPREAMP SENSOR WITH AST
WDIU-AST
WIDEBANDUNDERWATERSENSOR, W/AST&P
WD-T.C.
SENSOR, W/B, DIFF,WTOP CABLE
WDU
WSa
100-900 kHzwideband freq., SE sensor, SMA connector
更多咨询请登入  或者联系:小陶 18874821153 186139905980731-84668116 QQ:2376140740
tl130408 | 2013-9-4 10:13:04 | 显示全部楼层
欢迎广大无损检测的朋友进来。。。。。。。。。。。。。
