[分享] ECISS/TC 2 Steel - Physico-chemical and non-destructive testing,钢/物理...
查看5743 | 回复1 | 2013-8-11 14:46:50 | 显示全部楼层 |阅读模式
欧洲标准目录
钢/物理-化学和无损检测
EN 10160:1999 Ultrasonic testing of steel flat product of thickness equal or greater than 6 mm (reflection method)
厚度大于或等于6mm的钢板超声检测(反射方法)
EN 10306:2001 Iron and steel - Ultrasonic testing of H beams with parallel flanges and IPE beams
EN 10307:2001 Non-destructive testing - Ultrasonic testing of austenitic and austenitic-ferritic stainless steels flat products of thickness equal to or greater than 6 mm (reflection method)
无损检测  厚度大于或等于6mm的奥氏体和铁素奥氏体不锈钢板超声检测(反射方法)
EN 10308:2001 Non destructive testing - Ultrasonic testing of steel bars
无损检测  条钢超声检测
fgh222 | 2016-1-29 22:33:58 | 显示全部楼层
看看了
