[分享] ISO/TC135 Non-destructive testing,无损检测
查看7141 | 回复0 | 2013-8-11 14:40:22 | 显示全部楼层 |阅读模式
国际标准目录
ISO 2400:1972
Welds in steel -- Reference block for the calibration of equipment for ultrasonic examination
钢焊缝  超声检测设备校准用参考试块
ISO 3057:1998
Non-destructive testing -- Metallographic replica techniques of surface examination
无损检测  表面检测的金相复型技术
ISO 3058:1998
Non-destructive testing -- Aids to visual inspection -- Selection of low-power magnifiers
无损检测  目视检测辅助设备  低倍放大镜的选择
ISO 3059:2001
Non-destructive testing -- Penetrant testing and magnetic particle testing - Viewing conditions
无损检测  渗透检测和磁粉检测  观察条件
ISO 3452-1:2008
Non-destructive testing -- Penetrant testing -- Part 1: General principles
无损检测  渗透检测  第 1 部分:总则
ISO 3452-2:2006
Non-destructive testing -- Penetrant testing -- Part 2: Testing of penetrant materials
无损检测  渗透检测  第 2 部分:渗透材料的检验
ISO 3452-3:1998
Non-destructive testing -- Penetrant testing -- Part 3: Reference test blocks
无损检测  渗透检测  第 3 部分:参考试块
ISO 3452-4:1998
Non-destructive testing -- Penetrant testing -- Part 4: Equipment
无损检测  渗透检测  第 4 部分:设备
ISO 3452-5:2008
Non-destructive testing -- Penetrant testing -- Part 5: Penetrant testing at temperatures higher than 50 degrees C
无损检测  渗透检测  第 5 部分:50 ºC 以上的高温渗透检测
ISO 3452-6:2008
Non-destructive testing -- Penetrant testing -- Part 6: Penetrant testing at temperatures lower than 10 degrees C
无损检测  渗透检测  第 6 部分:10 ºC 以下的低温渗透检测
ISO 3530:1979
Vacuum technology -- Mass-spectrometer-type leak-detector calibration
真空技术  质谱检漏仪校准
ISO 5576:1997
Non-destructive testing -- Industrial X-ray and gamma-ray radiology -- Vocabulary
无损检测  工业 X 射线和伽玛射线照相  词汇
ISO 5577:2000
Non-destructive testing -- Ultrasonic inspection -- Vocabulary
无损检测  超声检测  词汇
ISO 5579:1998
Non-destructive testing -- Radiographic examination of metallic materials by X- and gamma rays -- Basic rules
无损检测  金属材料 X 和伽玛射线照相检测  基本规则
ISO 5580:1985
Non-destructive testing -- Industrial radiographic illuminators -- Minimum requirements
无损检测  工业射线照相观片灯  最低要求
ISO 7963:2006
Non-destructive testing -- Ultrasonic testing --- Specification for calibration block No. 2
无损检测  超声检测  2号校准试块技术条件
ISO 9712:2005
Non-destructive testing -- Qualification and certification of personnel
无损检测  人员资格鉴定与认证
ISO 9934-1:2001
Non-destructive testing -- Magnetic particle testing -- Part 1: General principles
无损检测  磁粉检测  第 1 部分:总则
ISO 9934-2:2002
Non-destructive testing -- Magnetic particle testing -- Part 2: Detection media
无损检测  磁粉检测  第 2 部分:检测介质
ISO 9934-3:2002
Non-destructive testing -- Magnetic particle testing -- Part 3: Equipment
无损检测  磁粉检测  第 3 部分:设备
ISO 10375:1997
Non-destructive testing -- Ultrasonic inspection -- Characterization of search unit and sound field
无损检测  超声检测  探头及其声场的表征
ISO 11537:1998
Non-destructive testing -- Thermal neutron radiographic testing -- General principles and basic rules
无损检测  热中子辐射照相检测  总则和基本规则
ISO 11699-1:2008
Non-destructive testing -- Industrial radiographic film -- Part 1: Classification of film systems for industrial radiography
无损检测  工业射线照相胶片  第 1 部分:工业射线照相胶片系统的分类
ISO 11699-2:1998
Non-destructive testing -- Industrial radiographic films -- Part 2: Control of film processing by means of reference values
无损检测  工业射线照相胶片  第 2 部分:用参考值方法控制胶片处理
ISO 12706:2000
Non-destructive testing -- Terminology - Terms used in penetrant testing
无损检测  术语  渗透检测
ISO 12710:2002
Non-destructive testing -- Ultrasonic inspection -- Evaluating electronic characteristics of ultrasonic test instruments
无损检测  超声检测  超声检测仪电特性的评定
ISO 12713:1998
Non-destructive testing -- Acoustic emission inspection -- Primary calibration of transducers
无损检测  声发射检测  换能器的一级校准
ISO 12714:1999
Non-destructive testing -- Acoustic emission inspection -- Secondary calibration of acoustic emission sensors
无损检测  声发射检测  声发射传感器的二级校准
ISO 12715:1999
Ultrasonic non-destructive testing -- Reference blocks and test procedures for the characterization of contact search unit beam profiles
超声无损检测  表征接触式探头声束截面性能的参考试块和测试规程
ISO 12716:2001
Non-destructive testing -- Acoustic emission inspection -- Vocabulary
无损检测  声发射检测  词汇
ISO 12718:2008
Non-destructive testing -- Eddy current testing -- Vocabulary
无损检测  涡流检测  词汇
ISO 12721:2000
Non-destructive testing -- Thermal neutron radiographic testing -- Determination of beam L/D ratio
无损检测  热中子辐射照相检测  中子束 L/D 的测定
ISO 14096-1:2005
Non-destructive testing -- Qualification of radiographic film digitisation systems -- Part 1: Definitions, quantitative measurements of image quality parameters, standard reference film and qualitative control
无损检测 射线照相胶片数字系统的质量鉴定 第 1 部分:定义、像质参数的定量测量、标准参考胶片和定量控制
ISO 14096-2:2005
Non-destructive testing -- Qualification of radiographic film digitisation systems -- Part 2: Minimum requirements
无损检测 射线照相胶片数字系统的质量鉴定 第 2 部分:最低要求
ISO 15548-1:2008
Non-destructive testing -- Equipment for eddy current examination -- Part 1: Instrument characteristics and verification
无损检测  涡流检测设备  第1部分:仪器特性与验证
ISO 15548-2:2008
Non-destructive testing -- Equipment for eddy current examination -- Part 2: Probe characteristics and verification
无损检测  涡流检测设备  第2部分:探头特性与验证
ISO 15548-3:2008
Non-destructive testing -- Equipment for eddy current examination -- Part 3: System characteristics and verification
无损检测  涡流检测设备  第3部分:系统特性与验证
ISO 15549:2008
Non-destructive testing -- Eddy current testing -- General principles
无损检测  涡流检测  总则
ISO 15708-1:2002
Non-destructive testing -- Radiation methods -- Computed tomography -- Part 1: Principles
无损检测  辐射方法  计算机层析成像  第 1 部分:原则
ISO 15708-2:2002
Non-destructive testing -- Radiation methods -- Computed tomography -- Part 2: Examination practices
无损检测  辐射方法  计算机层析成像  第 2 部分:检测方法
ISO/TS 18173:2005
Non-destructive testing -- General terms and definitions
无损检测  通用术语和定义
ISO 18175:2004
Non-destructive testing -- Evaluating performance characteristics of ultrasonic pulse-echo testing systems without the use of electronic measurement instruments
无损检测 不用电子测量仪器评定超声脉冲回波检测系统工作特性
ISO 19232-1:2004
Non-destructive testing -- Image quality of radiographs -- Part 1: Image quality indicators (wire type) -- Determination of image quality value
无损检测 射线照相底片像质 第1部分:线型像质计 像质指数的测定
ISO 19232-2:2004
Non-destructive testing -- Image quality of radiographs -- Part 2: Image quality indicators (step/hole type) -- Determination of image quality value
无损检测 射线照相底片像质 第2部分:阶梯孔型像质计 像质指数的测定
ISO 19232-3:2004
Non-destructive testing -- Image quality of radiographs -- Part 3: Image quality classes for ferrous metals
无损检测 射线照相底片像质 第3部分:黑色金属像质分类
ISO 19232-4:2004
Non-destructive testing -- Image quality of radiographs -- Part 4: Experimental evaluation of image quality values and image quality tables
无损检测 射线照相底片像质 第4部分:像质指数和像质表的实验评价
ISO 19232-5:2004
Non-destructive testing -- Image quality of radiographs -- Part 5: Image quality indicators (duplex wire type) -- Determination of image unsharpness value
无损检测 射线照相底片像质 第5部分:双线型像质计 图像不清晰度的测定
ISO 20807:2004
Non-destructive testing -- Qualification of personnel for limited application of non-destructive testing
无损检测 有限应用范围的无损检测人员资格鉴定
ISO/TS 21432:2005
Non-destructive testing -- Standard test method for determining residual stresses by neutron diffraction
无损检测 测定残余应力的中子衍射方法
ISO/TS 22809:2007
Non-destructive testing -- Discontinuities in specimens for use in qualification examinations
无损检测  资格考试用试样中的不连续
ISO/TR 25107:2006
Non-destructive testing -- Guidelines for NDT training syllabuses
无损检测  NDT培训课程指南
ISO/TR 25108:2006
Non-destructive testing -- Guidelines for NDT personnel training organizations
无损检测  NDT人员培训机构指南
