[分享] ISO/TC 107 Metallic and other inorganic coatings,金属及其他无机覆...
查看4002 | 回复0 | 2013-8-11 14:38:50 | 显示全部楼层 |阅读模式
ISO/TC 107  Metallic and other inorganic coatings,金属及其他无机覆盖层
ISO 1463:2003
Metallic and oxide coatings -- Measurement of coating thickness -- Microscopical method
金属和氧化物覆盖层  覆盖层厚度测量  显微镜方法
ISO 2064:1996
Metallic and other inorganic coatings -- Definitions and conventions concerning the measurement of thickness
金属和其他无机覆盖层  厚度测量的定义和惯例
ISO 2178:1982
Non-magnetic coatings on magnetic substrates -- Measurement of coating thickness -- Magnetic method
磁性基体上非磁性覆盖层  覆盖层厚度测量  磁性方法
ISO 2360:2003
Non-conductive coatings on non-magnetic electrically conductive basis materials -- Measurement of coating thickness -- Amplitude-sensitive eddy current method
非磁性导电基体上非导电覆盖层  覆盖层厚度测量  调幅感应涡流方法
ISO 2361:1982
Electrodeposited nickel coatings on magnetic and non-magnetic substrates -- Measurement of coating thickness -- Magnetic method
磁性和非磁性基体上镍电镀层  镀层厚度测量  磁性方法
ISO 3497:2000
Metallic coatings -- Measurement of coating thickness -- X-ray spectrometric methods
金属覆盖层  覆盖层厚度测量  X 射线光谱方法
ISO 3543:2000
Metallic and non-metallic coatings -- Measurement of thickness -- Beta backscatter method
金属和非金属覆盖层  厚度测量  β 背散射方法
ISO 3868:1976
Metallic and other non-organic coatings -- Measurement of coating thicknesses -- Fizeau multiple-beam interferometry method
金属和其他无机覆盖层  覆盖层厚度测量  裴索多光束干涉方法
ISO 3882:1986
Metallic and other non-organic coatings -- Review of methods of measurement of thickness
金属和其他无机覆盖层  厚度测量方法综述
ISO 4518:1980
Metallic coatings -- Measurement of coating thickness -- Profilometric method
金属覆盖层  覆盖层厚度测量  轮廓仪方法
ISO 4522-1:1985
Metallic coatings -- Test methods for electrodeposited silver and silver alloy coatings -- Part 1: Determination of coating thickness
金属覆盖层  银和银合金电镀层厚度检测方法  第 1 部分:镀层厚度测定
ISO 4524-1:1985
Metallic coatings -- Test methods for electrodeposited gold and gold alloy coatings -- Part 1: Determination of coating thickness
金属覆盖层  金和金合金电镀层厚度检测方法  第 1 部分:镀层厚度测定
ISO 9220:1988
Metallic coatings -- Measurement of coating thickness -- Scanning electron microscope method
金属覆盖层  覆盖层厚度测量  扫描电子显微镜方法
