| 年份 | | | | | | |
| | | | | | Residual Stress Nondestructive Testing for Pipe Component Based on Ultrasonic Method |
| | | | Elastic waves characteristics in thick-walled hollow cylinders with internal/external surface excitation for train axle monitoring |
| | | Emissivity-adjusted based depth profiling in eddy current pulsed thermography |
| | | | Phased Array B-scan Acoustic Field Simulation of Aluminum Extrudate FSW Welds with Complex Shapes |
| | | Modified Synthetic Focusing with Direction of Arrival Function for Ultrasound |
| | | Ultrafast Surface-Inspecting Laser Scanner |
| | | | 时频分析方法测量GLARE板中空气耦合兰姆波的频散特性 |
| | | | 基于柔性涡流探头的托卡马克内部线圈导体偏心涡流检测方法研究 |
| | | | | | Acoustoelastic Lamb wave analysis in thin plates |
| | | | Cross-correlation Phase Correction Method on Ultrasonic Synthetic Focused Signal Distortion |
| | | Ferrite-yoke based pulsed induction thermography for cracks quantitative evaluation |
| | | | Quantitative determination of surface cracks by the laser optoacoustic method |
| | | Analysis of Dynamic Characteristic for Ultra-thin Coating Layer with Ultrasonic Atomic Force Microscopy |
| | | Study on Focusing Characteristics of Curved Phased Array Probe |
| | | Implementing Ultrasonic Guided Wave Mode Control in Hollow Cylinders |
| | | | | 基于巴克豪森原理的Q235钢不同深度应力分布检测研究 |
| | | | | | Research of SNR Enhancement for Coarse-grained CASS Based on Phase Coherence Imaging |
| | | | Experimental Study of Turbine Disk Residual Stress Measurement Using Lcr Wave |
| | | Feasibility study of Debonding NDT for Multi-layer met-al-metal bonding structure by using eddy current pulse thermography |
| | | | Unidirectional Line-Focusing Shear Vertical Wave EMATs used for rail base center flaw detection |
| | | Experimental investigation into Probability of Detection for Fatigue Cracks in Sonic IR Imaging |
| | | Multi-aperture focus ultrasonic imaging technique based on virtual source |
| | | Localization and Evaluation of Subsurface Pits in Copper Pipes Using Gradient-field Pulsed Eddy Current Inspection |
| | | | | | Statistical properties of Barkhausen Noise with 180 degree domain wall for stress characterization and grain boundary effects |
| | | | Development of Electromagnetic nondestructive testing for inspecting mechanical lap joint of high-temperature superconducting tapes |
| | | Recognition of key targets of locomotive bottom based on 3D point cloud data |
| Nanyang Technological University | | An adaptive regularization method for limited view thickness reconstruction |
| | | | patial-time-step Features Fusion algorithm in Eddy Current Pulsed Thermography |
| | | Probability of Detection for Fatigue Crack in Pulsed Eddy Current Thermography |
| | | Effects of interlaminar electrical behavior on eddy currents in carbon fiber composite materials |
| | | Circumferential current field testing method for inspection of inner-wall cracks in aluminum tube |
| | | Welding Defects Detection and Classification by Using Eddy Current Thermography |
| University of Texas at Dallas | | Power Efficient Ultrasound Imaging Diagnosis System Using Adaptive Data Prediction Scheme |
| | | 球墨铸铁QT400-18石墨球化率对超声声速的影响 |
