[分享] CEN/TC 138 Non-destructive testing,无损检测
查看3859 | 回复0 | 2013-8-11 14:43:45 | 显示全部楼层 |阅读模式
欧洲标准目录
CEN ISO/TS 21432:2005 Non-destructive testing - Standards test method for determining residual stresses by neutron diffraction (ISO 21432:2005)
无损检测 测定残余应力的中子衍射方法
CEN/TR 14748:2004 Non-destructive testing - Methodology for qualification of non-destructive tests
无损检测  无损检测的鉴定方法
CEN/TS 15053:2005 Non-destructive testing - Recommendations for discontinuities-types in test specimens for examination
无损检测  推荐的考试用检测试样中的不连续类型
CR 13935:2000 Non-destructive testing - Generic NDE data format model
无损检测  普通NDE数据格式模型
EN 12084:2001 Non-destructive testing - Eddy current testing - General principles and guidelines
EN 12084:2001/A1:2003 Non-destructive testing - Eddy current testing - General principles and guidelines
无损检测  涡流检测  总则与指南
EN 12223:1999 Non-destructive testing - Ultrasonic examination - Specification for calibration block No. 1
无损检测  超声检测  1 号校准试块规格
EN 12543-1:1999 Non-destructive testing - Characteristics of focal spots in industrial X-ray systems for use in non-destructive testing - Part 1: Scanning method
无损检测  无损检测用工业X射线系统焦点特性  第 1 部分:扫描方法
EN 12543-2:2008 Non-destructive testing - Characteristics of focal spots in industrial X-ray systems for use in non-destructive testing - Part 2: Pinhole camera radiographic method
无损检测  无损检测用工业X射线系统焦点特性  第 2 部分:针孔射线照相方法
EN 12543-3:1999 Non-destructive testing - Characteristics of focal spots in industrial X-ray systems for use in non-destructive testing - Part 3: Slit camera radiographic method
无损检测  无损检测用工业X射线系统焦点特性  第 3 部分:狭缝射线照相方法
EN 12543-4:1999 Non-destructive testing - Characteristics of focal spots in industrial X-ray systems for use in non-destructive testing - Part 4: Edge method
无损检测  无损检测用工业X射线系统焦点特性  第 4 部分:边缘方法
EN 12543-5:1999 Non-destructive testing - Characteristics of focal spots in industrial X-ray systems for use in non-destructive testing - Part 5: Measurement of the effective focal spot size of mini and micro focus X-ray tubes
无损检测  无损检测用工业X射线系统焦点特性  第 5 部分:小和微小焦点 X 射线管有效焦点尺寸的测量
EN 12544-1:1999 Non-destructive testing - Measurement and evaluation of the X-ray tube voltage - Part 1: Voltage divider method
无损检测  X射线管电压的测量与评价  第 1 部分:电压分压器方法
EN 12544-2:2000 Non-destructive testing - Measurement and evaluation of the X-ray tube voltage - Part 2: Constancy check by the thick filter method
无损检测  X射线管电压的测量与评价  第 2 部分:用厚过滤器的恒定校验方法
EN 12544-3:1999 Non-destructive testing - Measurement and evaluation of the X-ray tube voltage - Part 3: Spectrometric method
无损检测  X射线管电压的测量与评价  第 3 部分:频谱方法
EN 12668-1:2000 Non-destructive testing - Characterization and verification of ultrasonic examination equipment - Part 1: Instruments
EN 12668-1:2000/A1:2004 Non-destructive testing - Characterization and verification of ultrasonic examination equipment - Part 1: Instruments
无损检测  超声检测设备的性能与验证  第 1 部分:仪器
EN 12668-2:2001 Non-destructive testing - Characterization and verification of ultrasonic examination equipment - Part 2: Probes
EN 12668-2:2001/A1:2004 Non-destructive testing - Characterization and verification of ultrasonic examination equipment - Part 2: Probes
无损检测  超声检测设备的性能与验证  第 2 部分:探头
EN 12668-3:2000 Non-destructive testing - Characterization and verification of ultrasonic examination equipment - Part 3: Combined equipment
EN 12668-3:2000/A1:2004 Non-destructive testing - Characterization and verification of ultrasonic examination equipment - Part 3: Combined equipment
无损检测  超声检测设备的性能与验证  第 3 部分:组合设备
EN 12679:1999 Non-destructive testing - Determination of the size of industrial radiographic sources - Radiographic method
无损检测  工业射线照相源尺寸的测定  射线照相方法
EN 13018:2001 Non-destructive testing - Visual testing - General principles
EN 13018:2001/A1:2003 Non-destructive testing - Visual testing - General principles
无损检测  目视检测  总则
EN 13068-1:1999 Non-destructive testing - Radioscopic testing - Part 1: Quantitative measurement of imaging properties
无损检测  射线透视检测  第 1 部分:成像性能的定量测量
EN 13068-2:1999 Non-destructive testing - Radioscopic testing - Part 2: Check of long term stability of imaging devices
无损检测  射线透视检测  第 2 部分:成像装置长期稳定性的校验
EN 13068-3:2001 Non-destructive testing - Radioscopic testing - Part 3: General principles of radioscopic testing of metallic materials by X- and gamma rays
无损检测  射线透视检测  第 3 部分:金属材料 X 和伽玛射线透视检测总则
EN 13184:2001 Non-destructive testing - Leak testing - Pressure change method
EN 13184:2001/A1:2003 Non-destructive testing - Leak testing - Pressure change method
无损检测  泄漏检测  变压方法
EN 13185:2001 Non-destructive testing - Leak testing - Tracer gas method
EN 13185:2001/A1:2003 Non-destructive testing - Leak testing - Tracer gas method
无损检测  泄漏检测  示踪气体方法
EN 13192:2001 Non destructive testing - Leak testing - Calibration of reference leaks for gases
EN 13192:2001/AC:2003 Non destructive testing - Leak testing - Calibration of reference leaks for gases
无损检测  泄漏检测  参考泄漏气体的校准
EN 1330-1:1998 Non destructive testing - Terminology - Part 1: List of general terms
无损检测  术语  第 1 部分:一般术语
EN 1330-10:2003 Non-destructive testing - Terminology - Part 10: Terms used in visual testing
无损检测  术语  第 10 部分:目视检测
EN 1330-2:1998 Non destructive testing - Terminology - Part 2: Terms common to the non-destructive testing methods
无损检测  术语  第 2 部分:无损检测方法通用术语
EN 1330-3:1997 Non-destructive testing - Terminology - Part 3: Terms used in industrial radiographic testing
无损检测  术语  第 3 部分:工业射线照相检测
EN 1330-4:2000 Non destructive testing - Terminology - Part 4: Terms used in ultrasonic testing
无损检测  术语  第 4 部分:超声检测
EN 1330-5:1998 Non-destructive testing - Terminology - Part 5: Terms used in Eddy current testing
无损检测  术语  第 5 部分:涡流检测
EN 1330-7:2005 Non-destructive testing - Terminology - Part 7: Terms used in magnetic particle testing
无损检测 术语 第 7 部分:磁粉检测
EN 1330-8:1998 Non-destructive testing - Terminology - Part 8: Terms used in leak tightness testing
无损检测  术语  第 8 部分:泄漏检测
EN 1330-9:2000 Non-destructive testing - Terminology - Part 9: Terms used in acoustic emission testing
无损检测  术语  第 9 部分:声发射检测
EN 13477-1:2001 Non-destructive testing - Acoustic emission - Equipment characterisation - Part 1: Equipment description
无损检测  声发射  设备性能  第 1 部分:设备概述
EN 13477-2:2001 Non-destructive testing - Acoustic emission - Equipment characterisation - Part 2: Verification of operating characteristic
无损检测  声发射  设备性能  第 2 部分:操作特性的验证
EN 13554:2002 Non-destructive testing - Acoustic emission - General principles
EN 13554:2002/A1:2003 Non-destructive testing - Acoustic emission - General principles
无损检测  声发射  总则
EN 13625:2001 Non-destructive testing - Leak test - Guide to the selection of instrumentation for the measurement of gas leakage
无损检测  泄漏检测  气体泄漏测量仪的选择指南
EN 13860-1:2003 Non destructive testing - Eddy current examination - Equipment characteristics and verification - Part 1: Instrument characteristics and verification
无损检测  涡流检测  设备性能与验证  第 1 部分:仪器性能与验证
EN 13860-2:2003 Non-destructive testing - Eddy current examination - Equipment characteristics and verification - Part 2: Probe characteristics and verification
无损检测  涡流检测  设备性能与验证  第 2 部分:探头性能与验证
EN 13860-3:2003 Non-destructive testing - Eddy current examination - Equipment characteristics and verification - Part 3: System characteristics and verification
无损检测  涡流检测  设备性能与验证  第 3 部分:系统性能与验证
EN 13925-1:2003 Non-destructive testing - X-ray diffraction from polycrystalline and amorphous material - Part 1: General principles
无损检测  多晶和非晶材料的X射线衍射  第 1 部分:总则
EN 13925-2:2003 Non-destructive testing - X-ray diffraction from polycrystalline and amorphous materials - Part 2: Procedures
无损检测  多晶和非晶材料的X射线衍射  第 2 部分:工艺规程
EN 13925-3:2005 Non destructive testing - X ray diffraction from polycrystalline and amorphous materials - Part 3: Instruments
无损检测  多晶和非晶材料的X射线衍射  第 3 部分:仪器
EN 13927:2003 Non-destructive testing - Visual testing - Equipment
无损检测  目视检测  设备
EN 14096-1:2003 Non-destructive testing - Qualification of radiographic film digitisation systems - Part 1: Definitions, quantitative measurements of image quality parameters, standard reference film and qualitative control
无损检测  射线照相胶片数字系统的质量鉴定  第 1 部分:定义、像质参数的定量测量、标准参考胶片和定量控制
EN 14096-2:2003 Non-destructive testing - Qualification of radiographic film digitisation systems - Part 2: Minimum requirements
无损检测  射线照相胶片数字系统的质量鉴定  第 2 部分:最低要求
EN 14127:2004 Non-destructive testing - Ultrasonic thickness measurement
无损检测  超声测厚
EN 14584:2005 Non-destructive testing - Acoustic emission - Examination of metallic pressure equipment during proof testing - Planar location of AE sources
无损检测  声发射  金属压力设备调试期检测  AE源的平面定位
EN 14784-1:2005 Non-destructive testing - Industrial computed radiography with storage phosphor imaging plates - Part 1: Classification of systems
无损检测  存储式磷成像板工业计算机射线照相  第1 部分:系统分类
EN 14784-2:2005 Non-destructive testing - Industrial computed radiography with storage phosphor imaging plates - Part 2: General principles for testing of metallic materials using X-rays and gamma rays
无损检测  存储式磷成像板工业计算机射线照相  第2 部分:金属材料X射线和伽玛射线检测总则
EN 1518:1998 Non-destructive testing - Leak testing - Characterization of mass spectrometer leak detectors
无损检测  泄漏检测  质谱检漏仪的性能
EN 15305:2008 Non-destructive Testing - Test Method for Residual Stress analysis by X-ray Diffraction
EN 15317:2007 Non-destructive testing - Ultrasonic testing - Characterization and verification of ultrasonic thickness measuring equipment
EN 15495:2007 Non Destructive testing - Acoustic emission - Examination of metallic pressure equipment during proof testing - Zone location of AE sources
EN 1593:1999 Non-destructive testing - Leak testing - Bubble emission techniques
EN 1593:1999/A1:2003 Non-destructive testing - Leak testing - Bubble emission techniques
无损检测  泄漏检测  气泡技术
EN 1779:1999 Non-destructive testing - Leak testing - Criteria for method and technique selection
EN 1779:1999/A1:2003 Non-destructive testing - Leak testing - Criteria for method and technique selection
无损检测  泄漏检测  方法和技术选择准则
EN 25580:1992 Non-destructive testing - Industrial radiographic illuminators - Minimum requirements (ISO 5580:1985)
无损检测  工业射线照相观片灯  最低要求
EN 27963:1992 Welds in steel - Calibration block No. 2 for ultrasonic examination of welds (ISO 7963:1985)
钢焊缝  焊缝超声检测用 2 号校准试块
EN 444:1994 Non-destructive testing - General principles for radiographic examination of metallic materials by X- and gamma-rays
无损检测  金属材料 X 和伽玛射线照相检测总则
EN 462-1:1994 Non-destructive testing - Image quality of radiographs - Part 1: Image quality indicators (wire type) - Determination of image quality value
无损检测  射线照相底片像质  第 1 部分:线型像质计  像质值的测定
EN 462-2:1994 Non-destructive testing - Image quality of radiographs - Part 2: Image quality indicators (step/hole type) - Determination of image quality value
无损检测  射线照相底片像质  第 2 部分:阶梯孔型像质计  像质值的测定
EN 462-3:1996 Non-destructive testing - Image quality of radiographs - Part 3: Image quality classes for ferrous metals
无损检测  射线照相底片像质  第 3 部分:黑色金属像质级别
EN 462-4:1994 Non-destructive testing - Image quality of radiographs - Part 4: Experimental evaluation of image quality values and image quality tables
无损检测  射线照相底片像质  第 4 部分:像质值和像质表的实验评价
EN 462-5:1996 Non-destructive testing - Image quality of radiographs - Part 5: Image quality indicators (duplex wire type), determination of image unsharpness value
无损检测  射线照相底片像质  第 5 部分:双线型像质计  图像不清晰度的测定
EN 473:2008 Non destructive testing - Qualification and certification of NDT personnel - General principles
无损检测  NDT人员资格鉴定与认证  总则
EN 571-1:1997 Non destructive testing - Penetrant testing - Part 1: General principles
无损检测  渗透检测  第 1 部分:总则
EN 583-1:1998 Non-destructive testing - Ultrasonic examination - Part 1: General principles
EN 583-1:1998/A1:2003 Non-destructive testing - Ultrasonic examination - Part 1: General principles
无损检测  超声检测  第 1 部分:总则
EN 583-2:2001 Non-destructive testing - Ultrasonic examination - Part 2: Sensitivity and range setting
无损检测  超声检测  第 2 部分:灵敏度与测距调整
EN 583-3:1997 Non-destructive testing - Ultrasonic examination - Part 3: Transmission technique
无损检测  超声检测  第 3 部分:穿透技术
EN 583-4:2002 Non-destructive testing - Ultrasonic examination - Part 4: Examination for discontinuities perpendicular to the surface
EN 583-4:2002/A1:2003 Non-destructive testing - Ultrasonic examination - Part 4: Examination for discontinuities perpendicular to the surface
无损检测  超声检测  第 4 部分:垂直于表面的不连续的检测
EN 583-5:2000 Non-destructive testing - Ultrasonic examination - Part 5: Characterization and sizing of discontinuities
EN 583-5:2000/A1:2003 Non-destructive testing - Ultrasonic examination - Part 5: Characterization and sizing of discontinuities
无损检测  超声检测  第 5 部分:不连续的定性与定量
EN 583-6:2008 Non-destructive testing - Ultrasonic examination - Part 6: Time-of-flight diffraction technique as a method for detection and sizing of discontinuities
无损检测  超声检测  第 6 部分:用衍射声时技术检测和定量不连续
EN 584-1:1994 Non destructive testing - Industrial radiographic film - Part 1: Classification of film systems for industrial radiography
无损检测  工业射线照相胶片  第 1 部分:工业射线照相胶片系统的分类
EN 584-2:1996 Non destructive testing - Industrial radiographic film - Part 2: Control of film processing by means of reference values
无损检测  工业射线照相胶片  第 2 部分:用参考值方法控制胶片处理
EN ISO 12706:2000 Non-destructive testing - Terminology - Terms used in penetrant testing (ISO 12706:2000)
无损检测  术语  渗透检测
EN ISO 12718:2008 Non-destructive testing - Eddy current testing - Vocabulary (ISO 12718:2008)
EN ISO 15548-1:2008 Non-destructive testing - Equipment for eddy current examination - Part 1: Instrument characteristics and verification (ISO 15548-1:2008)
EN ISO 15548-2:2008 Non-destructive testing - Equipment for eddy current examination - Part 2: Probe characteristics and verification (ISO 15548-2:2008)
EN ISO 15548-3:2008 Non-destructive testing - Equipment for eddy current examination - Part 3: System characteristics and verification (ISO 15548-3:2008)
EN ISO 3059:2001 Non-destructive testing - Penetrant testing and magnetic particle testing - Viewing conditions (ISO 3059:2001)
无损检测  渗透检测和磁粉检测  观察条件
EN ISO 3452-2:2000 Non-destructive testing - Penetrant testing - Part 2: Testing of penetrant materials (ISO 3452-2:2000)
无损检测  渗透检测  第 2 部分:渗透材料的检验
EN ISO 3452-3:1998 Non-destructive testing - Penetrant testing - Part 3: Reference test blocks (ISO 3452-3:1998)
EN ISO 3452-3:1998/AC:2001 Non-destructive testing - Penetrant testing - Part 3: Reference test blocks (ISO 3452-3:1998)
无损检测  渗透检测  第 3 部分:参考试块
EN ISO 3452-4:1998 Non-destructive testing - Penetrant testing - Part 4: Equipment (ISO 3452-4:1998)
无损检测  渗透检测  第 4 部分:设备
EN ISO 3452-5:2008 Non-destructive testing - Penetrant testing - Part 5: Penetrant testing at temperatures higher than 50 degrees C (ISO 3452-5:2008)
EN ISO 3452-6:2008 Non-destructive testing - Penetrant testing - Part 6: Penetrant testing at temperatures
EN ISO 9934-1:2001 Non-destructive testing - Magnetic particle testing - Part 1: General principles (ISO 9934-1:2001)
EN ISO 9934-1:2001/A1:2003 Non-destructive testing - Magnetic particles testing - Part 1: General principles (ISO 9934-1:2003)
无损检测  磁粉检测  第 1 部分:总则
EN ISO 9934-2:2002 Non-destructive testing - Magnetic particle testing - Part 2: Detection media (ISO 9934-2:2002)
无损检测  磁粉检测  第 2 部分:检测介质
EN ISO 9934-3:2002 Non-destructive testing - Magnetic particle testing - Part 3: Equipment (ISO 9934-3:2002)
无损检测  磁粉检测  第 3 部分:设备
