[分享] 国际标准目录
查看3068 | 回复0 | 2013-8-11 14:31:44 | 显示全部楼层 |阅读模式
国际标准目录
ISO/TC 17  Steel,钢
ISO 4986:1992
Steel castings -- Magnetic particle inspection
铸钢件  磁粉检测
ISO 4987:1992
Steel castings -- Penetrant inspection
铸钢件  渗透检测
ISO 4992-1:2006
Steel castings -- Ultrasonic examination -- Part 1: Steel castings for general purposes
ISO 4992-2:2006
Steel castings -- Ultrasonic examination -- Part 2: Steel castings for highly stressed components
ISO 4993:1987
Steel castings -- Radiographic inspection
铸钢件  射线照相检测
ISO 5948:1994
Railway rolling stock material -- Ultrasonic acceptance testing
铁路车辆材料  超声验收检测
ISO 6933:1986
Railway rolling stock material -- Magnetic particle acceptance testing
铁路车辆材料  磁粉验收检测
ISO 9302:1994
Seamless and welded (except submerged arc-welded) steel tubes for pressure purposes -- Electromagnetic testing for verification of hydraulic leak-tightness
承压无缝和焊接(埋弧焊除外)钢管  验证水压密封性的电磁检测
ISO 9303:1989
Seamless and welded (except submerged arc-welded) steel tubes for pressure purposes -- Full peripheral ultrasonic testing for the detection of longitudinal imperfections
承压无缝和焊接(埋弧焊除外)钢管  探测纵向缺欠的全周超声检测
ISO 9304:1989
Seamless and welded (except submerged arc-welded) steel tubes for pressure purposes -- Eddy current testing for the detection of imperfections
承压无缝和焊接(埋弧焊除外)钢管  探测缺欠的涡流检测
ISO 9305:1989
Seamless steel tubes for pressure purposes -- Full peripheral ultrasonic testing for the detection of transverse imperfections
承压无缝钢管  探测横向缺欠的全周超声检测
ISO 9402:1989
Seamless and welded (except submerged arc-welded) steel tubes for pressure purposes -- Full peripheral magnetic transducer/flux leakage testing of ferromagnetic steel tubes for the detection of longitudinal imperfections
承压无缝和焊接(埋弧焊除外)钢管  探测铁磁性钢管纵向缺欠的全周磁换能器(漏磁)检测
ISO 9598:1989
Seamless steel tubes for pressure purposes -- Full peripheral magnetic transducer/flux leakage testing of ferromagnetic steel tubes for the detection of transverse imperfections
承压无缝钢管  探测铁磁性钢管横向缺欠的全周磁换能器(漏磁)检测
ISO 9764:1989
Electric resistance and induction welded steel tubes for pressure purposes -- Ultrasonic testing of the weld seam for the detection of longitudinal imperfections
承压电阻焊和感应焊钢管  探测焊缝纵向缺欠的超声检测
ISO 9765:1990
Submerged arc-welded steel tubes for pressure purposes -- Ultrasonic testing of the weld seam for the detection of longitudinal and/or transverse imperfections
承压埋弧焊钢管  探测焊缝纵向和(或)横向缺欠的超声检测
ISO 10124:1994
Seamless and welded (except submerged arc-welded) steel tubes for pressure purposes -- Ultrasonic testing for the detection of laminar imperfections
承压无缝和焊接(埋弧焊除外)钢管  探测分层缺欠的超声检测
ISO 10332:1994
Seamless and welded (except submerged arc-welded) steel tubes for pressure purposes -- Ultrasonic testing for the verification of hydraulic leak-tightness
承压无缝和焊接(埋弧焊除外)钢管  验证水压密封性的超声检测
ISO 10543:1993
Seamless and hot-stretch-reduced welded steel tubes for pressure purposes -- Full peripheral ultrasonic thickness testing
承压无缝和热拉缩径焊钢管  全周超声测厚
ISO 11484:1994
Steel tubes for pressure purposes -- Qualification and certification of non-destructive testing (NDT) personnel
承压钢管  无损检测人员资格鉴定与认证
ISO 11496:1993
Seamless and welded steel tubes for pressure purposes -- Ultrasonic testing of tube ends for the detection of laminar imperfections
承压无缝和焊接钢管  探测管端分层缺欠的超声检测
ISO 11971:2008
Steel and iron castings -- Visual examination of surface quality
铸钢件  表面质量的目视检测
ISO 12094:1994
Welded steel tubes for pressure purposes -- Ultrasonic testing for the detection of laminar imperfections in strips/plates used in the manufacture of welded tubes
承压焊接钢管  探测焊接管用带(板)材中分层缺欠的超声检测
ISO 12095:1994
Seamless and welded steel tubes for pressure purposes -- Liquid penetrant testing
承压无缝和焊接钢管  渗透检测
ISO 12096:1996
Submerged arc-welded steel tubes for pressure purposes -- Radiographic testing of the weld seam for the detection of imperfections
承压埋弧焊钢管  探测焊缝缺欠的射线照相检测
ISO 13663:1995
Welded steel tubes for pressure purposes -- Ultrasonic testing of the area adjacent to the weld seam for the detection of laminar imperfections
承压焊接钢管  探测焊缝附近分层缺欠的超声检测
ISO 13664:1997
Seamless and welded steel tubes for pressure purposes -- Magnetic particle inspection of the tube ends for the detection of laminar imperfections
承压无缝和焊接钢管  探测管端分层缺欠的磁粉检测
ISO 13665:1997
Seamless and welded steel tubes for pressure purposes -- Magnetic particle inspection of the tube body for the detection of surface imperfections
承压无缝和焊接钢管  探测管体表面缺欠的磁粉检测
ISO 17577:2006
Steel -- Ultrasonic testing for steel flat products of thickness equal to or greater than 6 mm
国际标准目录
ISO/TC 42  Photography,照相术
ISO 5-1:1984
Photography -- Density measurements -- Part 1: Terms, symbols and notations
照相术  密度测量  第 1 部分:术语、符号和标志
ISO 5-1:2009
Photography and graphic technology -- Density measurements -- Part 1: Geometry and functional notation
ISO 5-2:2001
Photography -- Density measurements -- Part 2: Geometric conditions for transmission density
照相术  密度测量  第 2 部分:透射密度的几何条件
ISO 5-2:2009
Photography and graphic technology -- Density measurements -- Part 2: Geometric conditions for transmittance density
ISO 5-3:1995
Photography -- Density measurements -- Part 3: Spectral conditions
照相术  密度测量  第 3 部分:光谱条件
ISO 5-3:2009
Photography and graphic technology -- Density measurements -- Part 3: Spectral conditions
ISO 5-4:1995
Photography -- Density measurements -- Part 4: Geometric conditions for reflection density
照相术  密度测量  第 4 部分:反射密度的几何条件
ISO 5-4:2009
Photography and graphic technology -- Density measurements -- Part 4: Geometric conditions for reflection density
ISO 5655:2000
Photography -- Industrial radiographic films (roll and sheet) and metal intensifying screens -- Dimensions
照相术  工业射线照相胶片(卷和张)和金属增感屏  尺寸
ISO 7004:2002
Photography -- Industrial radiographic films -- Determination of ISO speed, ISO average gradient and ISO gradients G2 and G4 when exposed to X- and gamma-radiation
照相术  工业射线照相胶片  X 和伽玛射线曝光时的 ISO 感光速度、ISO 平均梯度及 ISO 梯度 G2 和 G4 的测定
ISO 14807:2001
Photography -- Transmission and reflection densitometers -- Method for determining performance
国际标准目录
ISO/TC 44  Welding and allied processes,焊接及相关工艺
ISO 10675-1:2008
Non-destructive testing of welds -- Acceptance levels for radiographic testing -- Part 1: Steel, nickel, titanium and their alloys
ISO 17635:2003
Non-destructive testing of welds -- General rules for fusion welds in metallic materials
焊缝无损检测  金属材料熔焊通则
ISO 17636:2003
Non-destructive testing of welds -- Radiographic testing of fusion-welded joints
焊缝无损检测  熔焊接头射线照相检测
ISO 17637:2003
Non-destructive testing of welds -- Visual testing of fusion-welded joints
焊缝无损检测  熔焊接头目视检测
ISO 17638:2003
Non-destructive testing of welds -- Magnetic particle testing
焊缝无损检测  磁粉检测
ISO 17640:2005
Non-destructive testing of welds -- Ultrasonic testing of welded joints
焊缝无损检测  焊接接头超声检测
ISO 17643:2005
Non-destructive testing of welds -- Eddy current testing of welds by complex-plane analysis
焊缝无损检测  基于复平面分析的焊缝涡流检测
ISO 22825:2006
Non-destructive testing of welds -- Ultrasonic testing -- Testing of welds in austenitic steels and nickel-based alloys
焊缝无损检测  超声检测  奥氏体钢和镍基合金焊缝检测
ISO 23277:2006
Non-destructive testing of welds -- Penetrant testing of welds -- Acceptance levels
焊缝无损检测  焊缝渗透检测  验收等级
ISO 23278:2006
Non-destructive testing of welds -- Magnetic particle testing of welds -- Acceptance levels
焊缝无损检测  焊缝磁粉检测  验收等级
ISO 23279:2007
Non-destructive testing of welds -- Ultrasonic testing -- Characterization of indications in welds
焊缝无损检测  超声检测  焊缝中指示的特征
国际标准目录
ISO/TC 79  Light metals and their alloys,轻金属及其合金
ISO 2128:1976
Anodizing of aluminium and its alloys -- Determination of thickness of anodic oxide coatings -- Non-destructive measurement by split-beam microscope
铝及其合金的阳极氧化处理  阳极氧化层厚度测定  用分束显微镜作无损测量
ISO 9915:1992
Aluminium alloy castings -- Radiography testing
铝合金铸件  射线照相检测
ISO 9916:1991
Aluminium alloy and magnesium alloy castings -- Liquid penetrant inspection
铝合金和镁合金铸件  渗透检测
ISO 10049:1992
Aluminium alloy castings -- Visual method for assessing the porosity
铝合金铸件  评估孔隙度的目视方法
国际标准目录
ISO/TC 85  Nuclear energy,核能
ISO 1757:1996
Personal photographic dosemeters
个人照相剂量仪
ISO 2855:1976
Radioactive materials -- Packagings -- Test for contents leakage and radiation leakage
放射性材料  包装  内存物泄漏和辐射泄漏的检测
ISO 2919:1999
Radiation protection -- Sealed radioactive sources -- General requirements and classification
辐射防护  密封放射源  一般要求和分类
ISO 3999:2004Radiation protection -- Apparatus for industrial gamma radiography -- Specifications for performance, design and tests
辐射防护  工业伽玛射线照相装置  性能、设计和检验规范
ISO/TR 4826:1979
Sealed radioactive sources -- Leak test methods
密封放射源  泄漏检测方法
ISO 7212:1986
Enclosures for protection against ionizing radiation -- Lead shielding units for 50 mm and 100 mm thick walls
电离辐射防护栏  50 mm 和 100 mm 厚铝屏蔽装置
ISO 9978:1992
Radiation protection -- Sealed radioactive sources -- Leakage test methods
辐射防护  密封放射源  泄漏检测方法
ISO 11934:1997
X and gamma radiation -- Indirect- or direct- reading capacitor-type pocket dosemeters
X 和伽玛射线  非直读或直读式电容型袖珍辐射剂量仪
国际标准目录
ISO/TC 107  Metallic and other inorganic coatings,金属及其他无机覆盖层
ISO 1463:2003
Metallic and oxide coatings -- Measurement of coating thickness -- Microscopical method
金属和氧化物覆盖层  覆盖层厚度测量  显微镜方法
ISO 2064:1996
Metallic and other inorganic coatings -- Definitions and conventions concerning the measurement of thickness
金属和其他无机覆盖层  厚度测量的定义和惯例
ISO 2178:1982
Non-magnetic coatings on magnetic substrates -- Measurement of coating thickness -- Magnetic method
磁性基体上非磁性覆盖层  覆盖层厚度测量  磁性方法
ISO 2360:2003
Non-conductive coatings on non-magnetic electrically conductive basis materials -- Measurement of coating thickness -- Amplitude-sensitive eddy current method
非磁性导电基体上非导电覆盖层  覆盖层厚度测量  调幅感应涡流方法
ISO 2361:1982
Electrodeposited nickel coatings on magnetic and non-magnetic substrates -- Measurement of coating thickness -- Magnetic method
磁性和非磁性基体上镍电镀层  镀层厚度测量  磁性方法
ISO 3497:2000
Metallic coatings -- Measurement of coating thickness -- X-ray spectrometric methods
金属覆盖层  覆盖层厚度测量  X 射线光谱方法
ISO 3543:2000
Metallic and non-metallic coatings -- Measurement of thickness -- Beta backscatter method
金属和非金属覆盖层  厚度测量  β 背散射方法
ISO 3868:1976
Metallic and other non-organic coatings -- Measurement of coating thicknesses -- Fizeau multiple-beam interferometry method
金属和其他无机覆盖层  覆盖层厚度测量  裴索多光束干涉方法
ISO 3882:1986
Metallic and other non-organic coatings -- Review of methods of measurement of thickness
金属和其他无机覆盖层  厚度测量方法综述
ISO 4518:1980
Metallic coatings -- Measurement of coating thickness -- Profilometric method
金属覆盖层  覆盖层厚度测量  轮廓仪方法
ISO 4522-1:1985
Metallic coatings -- Test methods for electrodeposited silver and silver alloy coatings -- Part 1: Determination of coating thickness
金属覆盖层  银和银合金电镀层厚度检测方法  第 1 部分:镀层厚度测定
ISO 4524-1:1985
Metallic coatings -- Test methods for electrodeposited gold and gold alloy coatings -- Part 1: Determination of coating thickness
金属覆盖层  金和金合金电镀层厚度检测方法  第 1 部分:镀层厚度测定
ISO 9220:1988
Metallic coatings -- Measurement of coating thickness -- Scanning electron microscope method
金属覆盖层  覆盖层厚度测量  扫描电子显微镜方法
国际标准目录
ISO/TC 123  Plain bearings,滑动轴承
ISO 4386-1:1992
Plain bearings -- Metallic multilayer plain bearings -- Part 1: Non-destructive ultrasonic testing of bond
滑动轴承  金属多层滑动轴承  第 1 部分:联结处超声无损检测
ISO 4386-3:1992
Plain bearings -- Metallic multilayer plain bearings -- Part 3: Non-destructive penetrant testing
滑动轴承  金属多层滑动轴承  第 3 部分:渗透无损检测
国际标准目录
ISO/TC135  Non-destructive testing,无损检测
ISO 2400:1972
Welds in steel -- Reference block for the calibration of equipment for ultrasonic examination
钢焊缝  超声检测设备校准用参考试块
ISO 3057:1998
Non-destructive testing -- Metallographic replica techniques of surface examination
无损检测  表面检测的金相复型技术
ISO 3058:1998
Non-destructive testing -- Aids to visual inspection -- Selection of low-power magnifiers
无损检测  目视检测辅助设备  低倍放大镜的选择
ISO 3059:2001
Non-destructive testing -- Penetrant testing and magnetic particle testing - Viewing conditions
无损检测  渗透检测和磁粉检测  观察条件
ISO 3452-1:2008
Non-destructive testing -- Penetrant testing -- Part 1: General principles
无损检测  渗透检测  第 1 部分:总则
ISO 3452-2:2006
Non-destructive testing -- Penetrant testing -- Part 2: Testing of penetrant materials
无损检测  渗透检测  第 2 部分:渗透材料的检验
ISO 3452-3:1998
Non-destructive testing -- Penetrant testing -- Part 3: Reference test blocks
无损检测  渗透检测  第 3 部分:参考试块
ISO 3452-4:1998
Non-destructive testing -- Penetrant testing -- Part 4: Equipment
无损检测  渗透检测  第 4 部分:设备
ISO 3452-5:2008
Non-destructive testing -- Penetrant testing -- Part 5: Penetrant testing at temperatures higher than 50 degrees C
无损检测  渗透检测  第 5 部分:50 ºC 以上的高温渗透检测
ISO 3452-6:2008
Non-destructive testing -- Penetrant testing -- Part 6: Penetrant testing at temperatures lower than 10 degrees C
无损检测  渗透检测  第 6 部分:10 ºC 以下的低温渗透检测
ISO 3530:1979
Vacuum technology -- Mass-spectrometer-type leak-detector calibration
真空技术  质谱检漏仪校准
ISO 5576:1997
Non-destructive testing -- Industrial X-ray and gamma-ray radiology -- Vocabulary
无损检测  工业 X 射线和伽玛射线照相  词汇
ISO 5577:2000
Non-destructive testing -- Ultrasonic inspection -- Vocabulary
无损检测  超声检测  词汇
ISO 5579:1998
Non-destructive testing -- Radiographic examination of metallic materials by X- and gamma rays -- Basic rules
无损检测  金属材料 X 和伽玛射线照相检测  基本规则
ISO 5580:1985
Non-destructive testing -- Industrial radiographic illuminators -- Minimum requirements
无损检测  工业射线照相观片灯  最低要求
ISO 7963:2006
Non-destructive testing -- Ultrasonic testing --- Specification for calibration block No. 2
无损检测  超声检测  2号校准试块技术条件
ISO 9712:2005
Non-destructive testing -- Qualification and certification of personnel
无损检测  人员资格鉴定与认证
ISO 9934-1:2001
Non-destructive testing -- Magnetic particle testing -- Part 1: General principles
无损检测  磁粉检测  第 1 部分:总则
ISO 9934-2:2002
Non-destructive testing -- Magnetic particle testing -- Part 2: Detection media
无损检测  磁粉检测  第 2 部分:检测介质
ISO 9934-3:2002
Non-destructive testing -- Magnetic particle testing -- Part 3: Equipment
无损检测  磁粉检测  第 3 部分:设备
ISO 10375:1997
Non-destructive testing -- Ultrasonic inspection -- Characterization of search unit and sound field
无损检测  超声检测  探头及其声场的表征
ISO 11537:1998
Non-destructive testing -- Thermal neutron radiographic testing -- General principles and basic rules
无损检测  热中子辐射照相检测  总则和基本规则
ISO 11699-1:2008
Non-destructive testing -- Industrial radiographic film -- Part 1: Classification of film systems for industrial radiography
无损检测  工业射线照相胶片  第 1 部分:工业射线照相胶片系统的分类
ISO 11699-2:1998
Non-destructive testing -- Industrial radiographic films -- Part 2: Control of film processing by means of reference values
无损检测  工业射线照相胶片  第 2 部分:用参考值方法控制胶片处理
ISO 12706:2000
Non-destructive testing -- Terminology - Terms used in penetrant testing
无损检测  术语  渗透检测
ISO 12710:2002
Non-destructive testing -- Ultrasonic inspection -- Evaluating electronic characteristics of ultrasonic test instruments
无损检测  超声检测  超声检测仪电特性的评定
ISO 12713:1998
Non-destructive testing -- Acoustic emission inspection -- Primary calibration of transducers
无损检测  声发射检测  换能器的一级校准
ISO 12714:1999
Non-destructive testing -- Acoustic emission inspection -- Secondary calibration of acoustic emission sensors
无损检测  声发射检测  声发射传感器的二级校准
ISO 12715:1999
Ultrasonic non-destructive testing -- Reference blocks and test procedures for the characterization of contact search unit beam profiles
超声无损检测  表征接触式探头声束截面性能的参考试块和测试规程
ISO 12716:2001
Non-destructive testing -- Acoustic emission inspection -- Vocabulary
无损检测  声发射检测  词汇
ISO 12718:2008
Non-destructive testing -- Eddy current testing -- Vocabulary
无损检测  涡流检测  词汇
ISO 12721:2000
Non-destructive testing -- Thermal neutron radiographic testing -- Determination of beam L/D ratio
无损检测  热中子辐射照相检测  中子束 L/D 的测定
ISO 14096-1:2005
Non-destructive testing -- Qualification of radiographic film digitisation systems -- Part 1: Definitions, quantitative measurements of image quality parameters, standard reference film and qualitative control
无损检测 射线照相胶片数字系统的质量鉴定 第 1 部分:定义、像质参数的定量测量、标准参考胶片和定量控制
ISO 14096-2:2005
Non-destructive testing -- Qualification of radiographic film digitisation systems -- Part 2: Minimum requirements
无损检测 射线照相胶片数字系统的质量鉴定 第 2 部分:最低要求
ISO 15548-1:2008
Non-destructive testing -- Equipment for eddy current examination -- Part 1: Instrument characteristics and verification
无损检测  涡流检测设备  第1部分:仪器特性与验证
ISO 15548-2:2008
Non-destructive testing -- Equipment for eddy current examination -- Part 2: Probe characteristics and verification
无损检测  涡流检测设备  第2部分:探头特性与验证
ISO 15548-3:2008
Non-destructive testing -- Equipment for eddy current examination -- Part 3: System characteristics and verification
无损检测  涡流检测设备  第3部分:系统特性与验证
ISO 15549:2008
Non-destructive testing -- Eddy current testing -- General principles
无损检测  涡流检测  总则
ISO 15708-1:2002
Non-destructive testing -- Radiation methods -- Computed tomography -- Part 1: Principles
无损检测  辐射方法  计算机层析成像  第 1 部分:原则
ISO 15708-2:2002
Non-destructive testing -- Radiation methods -- Computed tomography -- Part 2: Examination practices
无损检测  辐射方法  计算机层析成像  第 2 部分:检测方法
ISO/TS 18173:2005
Non-destructive testing -- General terms and definitions
无损检测  通用术语和定义
ISO 18175:2004
Non-destructive testing -- Evaluating performance characteristics of ultrasonic pulse-echo testing systems without the use of electronic measurement instruments
无损检测 不用电子测量仪器评定超声脉冲回波检测系统工作特性
ISO 19232-1:2004
Non-destructive testing -- Image quality of radiographs -- Part 1: Image quality indicators (wire type) -- Determination of image quality value
无损检测 射线照相底片像质 第1部分:线型像质计 像质指数的测定
ISO 19232-2:2004
Non-destructive testing -- Image quality of radiographs -- Part 2: Image quality indicators (step/hole type) -- Determination of image quality value
无损检测 射线照相底片像质 第2部分:阶梯孔型像质计 像质指数的测定
ISO 19232-3:2004
Non-destructive testing -- Image quality of radiographs -- Part 3: Image quality classes for ferrous metals
无损检测 射线照相底片像质 第3部分:黑色金属像质分类
ISO 19232-4:2004
Non-destructive testing -- Image quality of radiographs -- Part 4: Experimental evaluation of image quality values and image quality tables
无损检测 射线照相底片像质 第4部分:像质指数和像质表的实验评价
ISO 19232-5:2004
Non-destructive testing -- Image quality of radiographs -- Part 5: Image quality indicators (duplex wire type) -- Determination of image unsharpness value
无损检测 射线照相底片像质 第5部分:双线型像质计 图像不清晰度的测定
ISO 20807:2004
Non-destructive testing -- Qualification of personnel for limited application of non-destructive testing
无损检测 有限应用范围的无损检测人员资格鉴定
ISO/TS 21432:2005
Non-destructive testing -- Standard test method for determining residual stresses by neutron diffraction
无损检测 测定残余应力的中子衍射方法
ISO/TS 22809:2007
Non-destructive testing -- Discontinuities in specimens for use in qualification examinations
无损检测  资格考试用试样中的不连续
ISO/TR 25107:2006
Non-destructive testing -- Guidelines for NDT training syllabuses
无损检测  NDT培训课程指南
ISO/TR 25108:2006
Non-destructive testing -- Guidelines for NDT personnel training organizations
无损检测  NDT人员培训机构指南
 2010-08-07
