关灯
开启左侧
[官方发布] 2017远东论坛学术报告报名(第七批:第265-第364场)
yuandong实名认证 发表于 2017-5-23 16:25:23 | 显示全部楼层 |阅读模式 打印 上一主题 下一主题
“2017远东无损检测新技术论坛”学术报告报名公告
(第七批:第265场至第364场)
自即日起分批公布已收到的2017远东无损检测新技术论坛学术报告报名,现将第七批265场-第364场学术报告的题目、报告人和所代表单位公布如下:
265、报告题目:非破坏性测试中分数阶导数的使用
Title of the report: The Use of Fractional Order Derivatives in Non-Destructive Testing
报告人:理查德.西科拉
Reporter: Ryszard Sikora
单位:西波美拉尼亚的理工大学
UnitWest Pomeranian University ofTechnology
摘要Abstract:
The fractional order derivatives and integrals are known since 1695 yearwhen Leibniz and L’Hospital initiated the discussion aimed at calculus based onfractional order derivatives and integrals. For a long time, areas forpractical applications of this calculus have not been found. The lack ofapplications has been caused by serious difficulties referring to possibilitiesof clear physical and technical interpretation of fractional calculusformulae.   Nevertheless, there are noobstacles in use of this calculus in more or less “virtual” areas, such as, forexample, control theory, where there exist many degrees of freedom inmathematical creation of control laws. The number of papers using fractional order derivatives refer toelectrical engineering. Unfortunately, substantial number of mentioned above publicationscontain serious errors.  There are manyformulations defining the fractional order integrals and derivatives. Thus, onehas to overcome problem of choice of the right formulation for problem beingsolved. It should be mentioned that the following three among them are commonlyused, i.e. Gruinvald-Letnikov, Caputo, Riemann-Liouville [1]. After selectingthe correct formulation, the calculations have to be performed.  On the beginning one has to define thelinear, fractional order elements of electric circuit   used in non-destructive testing, forexample, these can be elements applied for construction of the transducerdetecting flaws on the basis of eddy-current technique.  These elements are not expressed with units:Ohm, Henr and Farad. Their respective physical units depend on the order ofderivatives. To avoid inconsistencies referring to Kirchhoff's law the“dedicated” coefficients are introduced to formula describing each circuitelement:  . By means of above adjustmentof physical units the Kirchhoff’s law for serial RLC circuit will be kept. Thenfractional order differential equations describing circuits are treatedmathematically. As the essence of the proposed approach one can treat creationof circuits with desired frequency characteristics. The formulae will betreated as theoretical standards for designing of innovative diagnostic systemsbased on the eddy-current technique. Thus, the obtained systems can be treatedas filters which approximate the desired frequency characteristics. Theproposed systems enable identification of the defect parameters as well. Thefull paper will contain the necessary elements of theory of the fractionalorder calculus as well as theory of eddy currents method using fractional orderderivatives of time. The selected examples will be also provided.  The proposed method can be used in case ofother testing methods, those described by means of differential equations (e.g.ultrasonic testing and others).
266、报告题目:评价退化结构材料的磁增量磁导率的方法
Title of the report: Evaluation of Degradation of Structural Materials by Magnetic IncrementalPermeability Method
报告人:上野本
Reporter: T. Uchimoto
单位:东北大学工学研究科
UnitGraduate School of Engineering,Tohoku University
摘要Abstract:
Magnetic techniques are practically used for evaluation of variousdegradations in steel components such as plastic deformation, residual stressand creep damage, and so on. However, most magnetic techniques are influencedby electromagnetic noises. Incremental magnetic permeability method measurescoil impedance during the magnetization that is equivalent to incrementalpermeability. It has an advantage of less noise-sensitive feature, because ofnarrow band filtering in measuring impedance. In this talk, some applicationsof incremental permeability method are introduced: plastic deformation of carbonsteels, and microstructure change of high Cr ferritic steels by creepdegradation. Incremental permeability as function of applied field changesaccording to microstructure change. In addition, trajectory of impedance in acomplex plain shows characteristic behaviors. These phenomena are discussedthrough the apparent permeability and conductivity reconstructed from theimpedance change.
267、报告题目:使用超声导波的特性检查和监测粘结层缺陷复合结构
Title of the report: Inspection and monitoring of bond line defects in composite structuresusing ultrasonic feature guided waves
报告人:范铮博士
Reporter: Dr. Fan Zheng
单位: 新加坡南洋理工大学
UnitNanyang Technological University
摘要Abstract:
Adhesivebonding is widely used in aerospace composite structures, being the most commonmeans to fix skins to reinforcing elements, such as spars and stiffeners. Acontinuous well-cured bond can offer uniform stresses, good joint strength, andimproved fatigue and impact resistance, and is therefore crucial to theperformance of the entire structure. This talk presents a novel technology touse feature guided waves (FGW) for rapid screening of the bond-line between astiffener and a carbon-fiber-reinforced-polymer (CFRP) composite panel. SuchFGW is capable of concentrating the energy along the stiffener and bond-line,with little energy leaking into the plate. Semi-Analytical Finite Element(SAFE) method is applied to understand the modal properties of FGWs that existin the structure, using both the homogeneous and the heterogeneous model forthe composite panel. Promising modes with little dispersion and littleattenuation are identified from the modal analysis. Both 3D Finite Element (FE)simulations and experiments are performed to study the interaction of theselected FGW mode with defects in the adhesive bond, and the results showexcellent agreement. The reflection behavior and the wave-defect resonancephenomenon are investigated, which demonstrate the capability of the FGW forthe bond line inspection. A new structural health monitoring (SHM) techniquebased on a synthetically focusing method using a sparse array of sensors isalso presented.
268、报告题目:机器人辅助复杂工件的超声相控阵自动化检测
报告人:吕博
单位:图迈检测技术(成都)有限公司 (法国M2M中国分公司)
269、报告题目:基于重构算法的金属磁记忆信号分析
Title of the report: Analysis of Metal Magnetic Memory SignalsBased on Reconstruction Algorithm
报告人:李红梅博士
Reporter:Dr. Li Hongmei
单位:北方民族大学
UnitBeifang Univesity of Nationality
270、报告题目:基于模型的涡流评估板的不确定性表征
Title of the report: Uncertainty Characterization forModel-Based Eddy Current Evaluation of a Plate
报告人:范孟豹
Reporter:Fan Mengbao
单位:中国矿业大学
UnitSchool of Mechanical and Electrical Engineering, China University ofMining and Technology
摘要Abstract:
Model-based inversion method has been used to solvethe conductivity, thickness and lift-off of conductive material simultaneously.The input uncertainty will be propagated to the outputs. In this work,self-adaptive Monte Carlo was adopted to evaluate the uncertainty ofmodel-based inversion. This work could help to enhance the performances ofmodel-based inversion.
271、报告题目:基于远场涡流的碳钢管道缺陷外检测方法
Title of the report: Outside inspection method for carbonsteel pipe defects based on remote field eddy current
报告人:肖奇
Reporter:Xiao Qi
单位:湘潭大学机械工程院
UnitXiangtan university mechanical engineering college
272、报告题目:激光拼焊板的焊缝质量检测系统的研究
Title of the report: Laser Tailor Welded Blank QualityInspection System Research
报告人:卢浩宇
Reporter:Lu Haoyu
单位:上海优博检测科技有限公司
UnitInnerspec Technologies China, LLC.  Shanghai
摘要Abstract:
With the demands of lightweight vehicles, the lasertailor-welded blank is gradually becoming an essential part in the automotiveindustry. The quality of all welds must be evaluated after the welding processto avoid breaks after the blank stamping and during the vehicle life. There areseveral inspection methods for Tailor Welded Blanks, but only an ultrasonicsystem is capable of detecting internal defects at high speed in an industrialenvironment. This article describes the ultrasonic system based on EMATtechnology for Laser Weld inspection, in which guided waves are used to inspectthe thin plates. The excitation of sound waves occurs on the surface of the materialrather than in the probe. For this reason, EMAT has the benefit of no couplant,non contact, feasible for low or high temperature and easy to integrate withautomation system.
Keywords:  EMAT, Nondestructive testing, Laser weldingplate, Tailor Welded Blanks
273、报告题目:AFTM在小径管异种钢焊缝层间未融检测中的应用
Title of the report: The Application of AFTM for Testing ofLack of Inter-Run Fusion in Small Diameter Pipe Dissimilar Steel Welded Joints
报告人:杜益
Reporter:Du Yi
单位:图迈检测技术(成都)有限公司
UnitM2M (China) Co., LTD.
274、报告题目:TFM在石油天然气管道HIC检测中的应用
报告人:杜益
单位:图迈检测技术(成都)有限公司
275、报告题目:小径管CR射线检测图像分辨率研究
报告人:陈乐
单位:上海市特种设备监督检验技术研究院
276、报告题目:聚乙烯管道电熔焊接接头承插不到位的检测分析
报告人:梁玉梅
单位:山东科捷工程检测有限公司
摘要Abstract:
Polyethylene pipe iswidely used in the city gas pipeline, the current detection methods includesdestructive testing and visual inspection, however, the bad connection case isdifficult to find by the above methods, especially in the situation of urgentrepair and fixed joints, it can not meet the safety testing criterion. In thispaper, we proposed that phased array ultrasound detection enables fast andaccurate nondestructive testing that can meet the current needs.
277、报告题目:用于检查高温超导带材的机械搭接接头的电磁无损检测的发展
Title of the report: Development ofElectromagnetic nondestructive testing for inspecting mechanical lap joint ofhigh-temperature superconducting tapes
报告人:Weixi Chen
Reporter: Weixi Chen
单位:日本东北大学
UnitTohoku university
摘要Abstract:
To facilitate construction andmaintenance of nuclear fusion reactors, a remountable (demountable)high-temperature superconducting magnet was proposed. The magnet is assembledfrom several segments with mechanical joints. The electrical resistance ofjoint at cryogenic temperature (joint resistance) has great influence on theperformance of the magnet, a nondestructive testing technique at roomtemperature is highly demanded to predict joint resistance.  In this study, we focused on electricalcharacteristics of the joint to develop an electromagnetic NDT technique forinspecting the joint. To identify the factors relating to the joint resistanceand the correlation between the electrical characteristics, we observed crosssections of the joint using X-ray CT scan and measured the electricalresistance and impedance of the joint. We found a small air gap existing in thejoint that could possibly be the cause for increment in joint resistance,though we could not evaluate the degree of influence of such gap over measuredelectrical resistance and impedance result. We analyzed the causes by numericalmodels, and found arranging the current perpendicular to the joint surface iseffective for inspecting the joint. Then we used numerical models to evaluatethe feasibility of applying the direct measurement and eddy current testing forinspection, the result showed the possibility of detecting particular air cap,optimization of the measurement condition is required.
Keywords: fusionreactor, remountable high-temperature superconducting magnet, mechanical lapjoint, joint resistance, X-ray CT, eddy current testing       New energy structure health testing
278、报告题目:运用大数据分析无损检测仪器
Title of the report: Enabling Big DataAnalysis on NDT instruments
报告人:Changwen Xie
Reporter:Changwen Xie
单位:3I技术有限公司
Unit3i Tech Ltd
摘要Abstract:
Some safety critical objects, suchas the rail track, oil pipeline, etc. must be inspected regularly. The shorterinspection period, the higher cost will be. The longer inspection period, themore possible safety risk will be.  Thequestion is how often the inspection will be carried out, which have a minimumsafety risk and less costs on inspection? This paper employed the Big Data (BD)analysis technique, and proposed a Big Data Analysis Enabled NDT systemframework to resolve the issue.
Keywords: BigData analysis, NDT instruments, Others
279、报告题目:应力和温度对Q235钢中LCR波传播影响研究(残余应力检测与调控专场)
报告人:于文广
单位:中国石油大学(华东)
280、报告题目:低温相变对焊接残余应力的影响(残余应力检测与调控专场)
报告人:蒋文春
单位:中国石油大学(华东)
281、报告题目:PAUT和TOFD联合检测在巨型箱船上不等厚板对接焊缝的应用和分析(船舶无损检测专场)
报告人:朱健强
单位:上海江南长兴重工有限责任公司
282、报告题目:声发射检测在船舶海工领域的应用(船舶无损检测专场)
报告人:吴昊
单位:中国船级社实业公司
283、报告题目:超声波检测横向缺陷漏检案例分析(船舶无损检测专场)
报告人:王丽梅
单位:挪威船级社(中国)有限公司
284、报告题目:钢对接焊缝超声波检测定位偏差原因分析(船舶无损检测专场)
报告人:张纪鹏
单位:江南造船(集团)有限责任公司
285、报告题目:造船行业常规对接焊缝的衍射时差(TOFD)无损检测技术可行性研究(船舶无损检测专场)
报告人:陈海锋
单位:中船黄埔文冲船舶有限公司
286、报告题目:基座纵桁与内底板小角度角焊缝的超声波检测(船舶无损检测专场)
报告人:陈玉柱
单位:中船黄埔文冲船舶有限公司
287、报告题目:玻璃钢-橡胶复合材料内部缺陷超声无损检测(船舶无损检测专场)
报告人:王绍涵
单位:北京理工大学
288、报告题目:不同船级社对船舶焊缝射线检测要求解析(船舶无损检测专场)
报告人:刘宁
单位:广船国际有限公司
289、报告题目:铁磁性材料性能检测技术在带钢生产线的应用(电磁无损检测专场)
报告人:顾舒娅
单位:南京航空航天大学
290、报告题目:基于磁致伸缩特征参数的构件应力测试方法(电磁无损检测专场)
报告人:周静
单位:南京航空航天大学
291、报告题目:铁磁材料应力和损伤的微磁检测定量化研究(电磁无损检测专场)
报告人:时朋朋
单位:西安电子科技大学
292、报告题目:铁磁材料塑性变形与BH磁化参数量化关系研究(电磁无损检测专场)
报告人:王羽
单位:北方民族大学
293、报告题目:励磁作用下铁磁管道缺陷磁特性仿真研究(电磁无损检测专场)
报告人:马冰洋
单位:南昌航空大学
294、报告题目:遗传算法用于缺陷形状低频漏磁重构的方法研究(电磁无损检测专场)
报告人:焦敬品
单位:北京工业大学
295、报告题目:电磁超声技术在水电站蜗壳检测中的应用(电磁无损检测专场)
报告人:徐峰
单位:浙江省特种设备检验研究院
296、报告题目:基于PEC技术的双层导电涂层厚度检测方法研究(电磁无损检测专场)
报告人:于亚婷
单位:电子科技大学
297、报告题目:奥氏体锅炉管氧化皮堆积厚度脉冲涡流检测实验研究(电磁无损检测专场)
报告人:徐志远
单位:湘潭大学
298、报告题目:基于远场涡流的碳钢管道缺陷外检测方法(电磁无损检测专场)
报告人:徐志远
单位:湘潭大学
299、报告题目:一种用于薄层分辨的探地雷达反演方法(电磁无损检测专场)
报告人:叶盛波
单位:中国科学院电子学研究所
300、报告题目:用于薄层金属内部缺陷检测的TMR涡流探头设计(电磁无损检测专场)
报告人:刘丽辉
单位:国防科学技术大学
301、报告题目:SH导波EMATs声场指向性的三维仿真(电磁无损检测专场)
报告人:马早军
单位:哈尔滨工业大学
302、报告题目:基于轨面适应承载机构的钢轨表面缺陷检测方法(电磁无损检测专场)
报告人:白坚
单位:南京航空航天大学
303、报告题目:基于EMAT的磁致伸缩特性的测量(电磁无损检测专场)
报告人:邹华章
单位:南京航空航天大学
304、报告题目:基于透射式电涡流趋肤深度的仿真与实验研究(电磁无损检测专场)
报告人:周德强
单位:江南大学
305、报告题目:基于概率统计的巴克豪森信号特征分析(电磁无损检测专场)
报告人:张艳艳
单位:南京航空航天大学
306、报告题目:初始状态对微磁信号的影响(电磁无损检测专场)
报告人:金科
单位:西安电子科技大学
307、报告题目:基于KSRC的MBN特征融合在铁磁材料分类中的应用(电磁无损检测专场)
报告人:杭成
单位:南京航空航天大学
308、报告题目:复合材料层合板脱层损伤动态检测方法研究(电磁无损检测专场)
报告人:田淑侠
单位:郑州轻工业学院
309、报告题目:用于热障涂层检测的电磁/电容集成式传感器(电磁无损检测专场)
报告人:任远
单位:国防科技大学机电工程与自动化学院
310、报告题目:涡流渗透深度的影响因素研究(电磁无损检测专场)
报告人:张东利
单位:北方民族大学机电工程学院
311、报告题目:低频电磁技术在水冷壁管腐蚀检测中的应用(电磁无损检测专场)
报告人:陈华林
单位:广西壮族自治区特种设备检验研究院
312、报告题目:基于时频分析的无线道岔损伤监测与识别(高铁无损检测专场)
报告人:胡泮
单位:南京航空航天大学
313、报告题目:基于DCPDPEC的金属构件多缝状缺陷无损检测技术(高铁无损检测专场)
报告人:于亚婷
单位:电子科技大学
314、报告题目:基于斜探头的斜向裂纹超声成像研究(高铁无损检测专场)
报告人:陈怡星
单位:西南交通大学
315、报告题目:电磁脉冲热成像高速铁路钢轨运动扫描检测(高铁无损检测专场)
报告人:高运来
单位:南京航空航天大学
316、报告题目:基于激光超声技术的钢轨检测及其应用(高铁无损检测专场)
报告人:江奕
单位:南京航空航天大学
317、报告题目:光纤光栅在铁路轨道监测中的研究与应用(高铁无损检测专场)
报告人:宋颖
单位:石家庄铁道大学 交通运输学院
318、报告题目:基于WO3敏感层的声表面波氢气传感器(光声技术和超声检测专场)
报告人:范理
单位:南京大学声学研究所
319、报告题目:EBSD辅助表征粗晶奥氏体不锈钢的超声性能(光声技术和超声检测专场)
报告人:林莉
单位:大连理工大学
320、报告题目:新型电磁超声传感器的开发及应用(光声技术和超声检测专场)
报告人:裴翠祥
单位:西安交通大学
321、报告题目:基于可视图建模的声发射源定位方法研究(光声技术和超声检测专场)
报告人:刘贵杰
单位:中国海洋大学
322、报告题目:基于点源高斯声束模型的高频换能器声场分析(光声技术和超声检测专场)
报告人:张佳琪
单位:北京理工大学
323、报告题目:超声换能器声场的分析与仿真(光声技术和超声检测专场)
报告人:张佳琪
单位:北京理工大学
324、报告题目:PZT压电方片厚度振动的有限元分析(光声技术和超声检测专场)
报告人:张君善
单位:武警工程大学
325、报告题目:水冷散热板内流道超声成像的图像增强(光声技术和超声检测专场)
报告人:武二永
单位:浙江大学
326、报告题目:手动常规超声法检测焊接接头横向缺陷可行性关键因素的探讨(光声技术和超声检测专场)
报告人:张佳银
单位:中国特种设备检测研究院
327、报告题目:大型锅炉密排管束的导波检测技术研究(光声技术和超声检测专场)
报告人:于宝虹
单位:上海宝钢
328、报告题目:六自由度机械臂在堆焊层CCTV检查中的应用(核电装备无损检测专场)
报告人:石磊
单位:中广核检测技术有限公司
329、报告题目:超声检查在VVP贯穿件焊缝役前检查中的应用(核电装备无损检测专场)
报告人:叶新
单位:中广核检测技术有限公司
330报告题目:核电主管道奥氏体不锈钢焊缝相控阵超声检测技术(核电装备无损检测专场)
报告人:张晓峰
单位:北京市核建恒信检测技术有限公司
331、报告题目:基于自回归谱外推的小尺寸裂纹TOFD定量检测研究(核电装备无损检测专场)
报告人:林莉
单位:大连理工大学无损检测研究所
332、报告题目:核工程建造数字化无损检测应用展望(核电装备无损检测专场)
报告人:周炜璐
单位:北京市核建恒信检测技术有限公司
333、报告题目:射线照相检测中胶片系统一致性的验证(核电装备无损检测专场)
报告人:许遵言
单位:上海电气核电集团
334、报告题目:AP1000反应堆压力容器顶盖贯穿件J型焊缝检测技术介绍(核电装备无损检测专场)
报告人:代勤龙
单位:东方电气(广州)重型机器有限公司
335、报告题目:基于FMC/SMC的复合钢主管道焊缝TFM成像研究(核电装备无损检测专场)
报告人:林莉
单位:大连理工大学无损检测研究所
336、报告题目:双侧激光视觉跟踪同步检测机器人系统(机器人+无损检测专场)
报告人:李向东
单位:江苏省特种设备安全监督检验研究院
337、报告题目:基于神经网络的45钢硬度超声检测方法研究(机器人+无损检测专场)
报告人:谭君洋
单位:装甲兵工程学院再制造国防科技重点实验室
338、报告题目:多自由度柔性空气耦合超声检测系统研究(机器人+无损检测专场)
报告人:郭灿志
单位:北京理工大学
339、报告题目:热喷涂涂层典型缺陷的超声红外热像检测技术研究(机器人+无损检测专场)
报告人:董丽虹
单位:装甲兵工程学院
340、报告题目:压缩机缓冲罐焊缝缺陷检测应用技术研究
报告人:朱沈宾
单位:中国石油大学(北京)
341、报告题目:用于电站耐热钢损伤评价的磁滞无损评估技术
报告人:吴胜平
单位:江苏省特种设备安全监督检验研究院
342、报告题目:基于光学斩波的锁相热波成像技术
报告人:陈力
单位:南京诺威尔光电系统有限公司
343、报告题目:脉冲与锁相热波成像技术对铝蜂窝结构的检测
报告人:江海军
单位:南京诺威尔光电系统有限公司
344、报告题目:泡沫夹层结构CFRP超声特征成像检测技术
报告人:冯君伟
单位:南昌航空大学无损检测技术教育部重点实验室
345、报告题目:基于超声特征成像热障涂层脱粘缺陷检测
报告人:刘勋丰
单位:南昌航空大学 无损检测教育部重点实验室
346、报告题目:图像传感器卷帘快门及积分时间效应的分析
报告人:闫毅芊
单位:首都师范大学
347、报告题目:基于光纤光栅的飞机翼梁形变监测技术研究
报告人:张新华
单位:南京航空航天大学
348、报告题目:阵列超声导波多模态成像检测方法研究(十三五NQI专项专场)
报告人:焦敬品
单位:北京工业大学机械工程与应用电子技术学院
349、报告题目:基于液压鼓胀的材料微损测试技术研究(十三五NQI专项专场)
报告人:王汉奎
单位:中国特种设备检测研究院
350、报告题目:在线薄板对接焊缝缺陷检测方法的比较研究(十三五NQI专项专场)
报告人:张义凤
单位:上海金艺检测技术有限公司
351、报告题目:超大功率电磁超声激励源的开发(十三五NQI专项专场)
报告人:周进节
单位:中北大学
352、报告题目:Q235低碳钢的磁声发射特性(十三五NQI专项专场)
报告人:沈功田
单位:中国特种设备检测研究院
353、报告题目:级联积分梳状滤波器在超声检测系统中的应用(十三五NQI专项专场)
报告人:周文佳
单位:中国科学院声学研究所
354、报告题目:连续管对接工艺及接头超声波检测技术研究(石油管及装备无损检测技术专场)
报告人:马佼佼
单位:国家石油天然气管材工程技术研究中心/.宝鸡石油钢管有限责任公司
355、报告题目:X射线平板数字成像与胶片成像差异的试验比较(数字射线检测专场)
报告人:吴开斌
单位:武汉市锅炉压力容器检验研究所
356、报告题目:基于斜率试块方法的缺陷自身高度精确测量的数字射线检测技术(数字射线检测专场)
报告人:赵建江
单位:敦瑞科技(北京)有限公司
357、报告题目:微焦点X射线数字系统检测BGA的最佳放大倍率(数字射线检测专场)
报告人:杨龙
单位:无锡日联科技股份有限公司
358、报告题目:一种疲劳裂纹三维扩展对比分析方法(数字射线检测专场)
报告人:古玉祺
单位:南昌航空大学
359、报告题目:高能工业平板探测器性能测试对比研究(数字射线检测专场)
报告人:陈浩
单位:四川九九瑞迪数字成像检测技术有限公司
360、报告题目:热障涂层TGO纳米CT三维成像(数字射线检测专场)
报告人:吴靖雯
单位:南昌航空大学
361、报告题目:能量色散X射线光谱数据的分析与处理(数字射线检测专场)
报告人:伊相心
单位:南京航空航天大学
362、报告题目:相控阵超声检测耦合状态自动评判法则的研究(相控阵检测专场)
报告人:武二永
单位:浙江大学
363、报告题目:高速相控阵超声检测系统研究(相控阵检测专场)
报告人:张渝
单位:西南交通大学光电工程研究所
364、报告题目:PAUT探伤中船舶焊缝缺陷类型的识别研究(相控阵检测专场)
报告人:林家根
单位:广船国际有限公司计量检测中心
哎哎哎
*滑动验证:
6关注
32粉丝
467帖子
排行榜
