[分享] 无损检测日本标准目录
查看4067 | 回复0 | 2013-8-11 15:01:21 | 显示全部楼层 |阅读模式
无损检测日本标准目录
JIS G 0431:2001
鉄鋼製品の非破壊試験技術者の資格及び認証
Qualification and certification of non-destructive testing (NDT) personnel for steel products
JIS G 0565:1992
鉄鋼材料の磁粉探傷試験方法及び磁粉模様の分類
Method for magnetic particle testing of ferromagnetic materials and classification of magnetic particle indication
JIS G 0581:1999
鋳鋼品の放射線透過試験方法
Methods of radiographic examination for steel castings
JIS G 0582:2004
鋼管の超音波探傷検査方法
Ultrasonic examination for steel pipes and tubes
JIS G 0583:2004
鋼管の貫通コイル法による渦流探傷検査方法
Eddy current examination of steel pipes and tubes by encircling coil technique
JIS G 0584:2004
アーク溶接鋼管の超音波探傷検査方法
Ultrasonic examination for arc welded steel pipes
鋳鋼品の放射線透過検査
Radiographic inspection for steel castings
JIS H 0522:1999
アルミニウム鋳物の放射線透過試験方法及び透過写真の等級分類方法
Methods of radiographic test and classification by radiographs of aluminium castings
航空宇宙用非破壊検査員の技量認定基準
Aerospace nondestructive inspection personnel qualification and certification
非破壊試験用語
Terms and definitions of nondestructive testing
非破壊試験 ― 技術者の資格及び認証
Non-destructive testing -- Qualification and certification of personnel
放射線透過試験用透過度計
Radiographic image quality indicators for non-destructive testing
渦流探傷器の性能測定方法
Test methods for performance characteristics of eddy current testing instruments
渦流探傷装置の総合性能の測定方法
Test methods for performance characteristics of eddy current flaw detecting system
漏えい(洩)磁束探傷試験方法
Methods for magnetic leakage flux testing
磁粉探傷用交流極間式磁化器
AC yoke magnet for magnetic particle testing
発泡漏れ試験方法
Methods for bubble leak testing
ヘリウム漏れ試験方法の種類及びその選択
Standard recommended guide for the selection of helium leak testing
ヘリウム漏れ試験方法
Method for helium leak testing
放置法による漏れ試験方法
Test method for leaks using the pressure change measurement
アンモニア漏れ試験方法
Test method for leaks using ammonia gas
目視基準ゲージを用いた浸透探傷試験及び磁粉探傷試験の目視観察条件の確認方法
Confirmation method of calibration by visual calibration gauge on magnetic particle and liquid penetrant testing
圧力容器の耐圧試験などにおけるアコースティック・エミッション試験方法及び試験結果の等級分類方法
Methods for acoustic emission testing of pressure vessels during pressure tests and classification of test results
非破壊試験 ― 浸透探傷試験 ― 第1部:一般通則:浸透探傷試験方法及び浸透指示模様の分類
Non-destructive testing -- Penetrant testing -- Part 1: General principles -- Method for liquid penetrant testing and classification of the penetrant indication
非破壊試験 ― 浸透探傷試験 ― 第2部:浸透探傷剤の試験
Non-destructive testing -- Penetrant testing -- Part 2: Testing of penetrant materials
非破壊試験 ― 浸透探傷試験 ― 第3部:対比試験片
Non-destructive testing -- Penetrant testing -- Part 3: Reference test blocks
非破壊試験 ― 浸透探傷試験 ― 第4部:装置
Non-destructive testing -- Penetrant testing -- Part 4: Equipment
金属材料のパルス反射法による超音波探傷試験方法通則
General rule of ultrasonic testing of metals by pulse echo technique
超音波探傷試験用標準試験片
Standard test blocks for ultrasonic testing
超音波探触子の性能測定方法
Method for measurement of performance characteristics of ultrasonic probes
超音波探傷器の電気的性能測定方法
Method for assessing the electrical characteristics of ultrasonic testing instrument using pulse echo technique
超音波探傷装置の性能測定方法
Method for assessing the overall performance characteristics of ultrasonic pulse echo testing instrument
超音波パルス法による固体の音速の測定方法(対比試験片を用いる方法)
Method for measurement on ultrasonic velocity of solid by pulse technique using reference test piece
超音波パルス反射法による固体の超音波減衰係数の測定方法
Method for measurement of ultrasonic attenuation coefficient of solid by pulse echo technique
超音波パルス反射法による厚さ測定方法
Methods for measurement of thickness by ultrasonic pulse echo technique
パイプライン溶接部の非破壊試験方法
Method of nondestructive examination for weld of pipeline
鋼溶接部の超音波探傷試験方法
Method for ultrasonic examination for welds of ferritic steel
JIS Z 3070:1998
鋼溶接部の超音波自動探傷方法
Methods for automatic ultrasonic testing for welds of ferritic steel
JIS Z 3080:1995
アルミニウムの突合せ溶接部の超音波斜角探傷試験方法
Methods of ultrasonic angle beam examination for butt welds of aluminium plates
JIS Z 3081:1994
アルミニウム管溶接部の超音波斜角探傷試験方法
Methods of ultrasonic angle beam examination for welds of aluminium pipes and tubes
JIS Z 3082:1995
アルミニウムのT形溶接部の超音波探傷試験方法
Methods of ultrasonic examination for T type welds of aluminium plates
JIS Z 3104:1995
鋼溶接継手の放射線透過試験方法
Methods of radiographic examination for welded joints in steel
JIS Z 3105:2003
アルミニウム溶接継手の放射線透過試験方法
Methods of radiographic examination for welded joints in aluminium
JIS Z 3106:2001
ステンレス鋼溶接継手の放射線透過試験方法
Methods of radiographic examination for welded joints in stainless steel
JIS Z 3107:1993
チタン溶接部の放射線透過試験方法
Methods of radiographic examination for titanium welds by X-ray
工業用γ線装置
Industrial gamma-ray apparatus for radiography
工業用放射線透過写真観察器
Viewing illuminators for industrial radiograph
工業用X線装置
Industrial X-ray apparatus for radiographic testing
放射線応用計測器用線源容器
Source container of measuring instrument utilizing ionizing radiation
工業用X線装置の実効焦点寸法測定方法
Measurement of the effective focal spot size for industrial X-ray apparatus
2005-08-16
