[分享] ECISS/TC 29 Steel tubes and fittings for steel tubes,钢管
查看4913 | 回复2 | 2013-8-11 14:49:12 | 显示全部楼层 |阅读模式
欧洲标准目录
EN 10246-1:1996 Non destructive testing of steel tubes - Part 1: Automatic electromagnetic testing of seamless and welded (except submerged arc welded) ferromagnetic steel tubes for verification of hydraulic leak-tightness
钢管无损检测  第1部分:验证无缝和焊接(埋弧焊除外)铁磁性钢管水压密封性的电磁检测
EN 10246-10:2000 Non-destructive testing of steel tubes - Part 10: Radiographic testing of the weld seam of automatic fusion arc welded steel tubes for the detection of imperfections
钢管无损检测  第10部分:探测自动埋弧焊钢管焊缝缺欠的射线照相检测
EN 10246-11:2000 Non-destructive testing of steel tubes - Part 11: Liquid penetrant testing of seamless and welded steel tubes for the detection of surface imperfections
钢管无损检测  第11部分:探测无缝和焊接钢管表面缺欠的渗透检测
EN 10246-12:2000 Non-destructive testing of steel tubes - Part 12: Magnetic particle inspection of seamless and welded ferromagnetic steel tubes for the detection of surface imperfections
钢管无损检测  第12部分:探测无缝和焊接铁磁性钢管表面缺欠的磁粉检测
EN 10246-13:2000 Non-destructive testing of steel tubes - Part 13: Automatic full peripheral ultrasonic thickness testing for seamless and welded (except submerged arc welded) steel tubes
钢管无损检测  第13部分:无缝和焊接(埋弧焊除外)钢管自动全周超声测厚
EN 10246-14:1999 Non-destructive testing of steel tubes - Part 14: Automatic ultrasonic testing of seamless and welded (except submerged arc-welded) steel tubes for the detection of laminar imperfections
钢管无损检测  第14部分:探测无缝和焊接(埋弧焊除外)钢管分层缺欠的自动超声检测
EN 10246-15:2000 Non-destructive testing of steel tubes - Part 15: Automatic ultrasonic testing of strip/plate used in the manufacture of welded steel tubes for the detection of laminar imperfections
钢管无损检测  第15部分:探测焊接钢管用带(板)材中分层缺欠的自动超声检测
EN 10246-16:2000 Non-destructive testing of steel tubes - Part 16: Automatic ultrasonic testing of the area adjacent to the weld seam of welded steel tubes for the detection of laminar imperfections
钢管无损检测  第16部分:探测焊接钢管焊缝附近分层缺欠的自动超声检测
EN 10246-17:2000 Non-destructive testing of steel tubes - Part 17: Ultrasonic testing of tube ends of seamless and welded steel tubes for the detection of laminar imperfections
钢管无损检测  第17部分:探测无缝和焊接钢管管端分层缺欠的超声检测
EN 10246-18:2000 Non-destructive testing of steel tubes - Part 18: Magnetic particle inspection of tube ends of seamless and welded ferromagnetic steel tubes for the detection of laminar imperfections
钢管无损检测  第18部分:探测无缝和焊接铁磁性钢管管端分层缺欠的磁粉检测
EN 10246-2:2000 Non-destructive testing of steel tubes - Part 2: Automatic eddy current testing of seamless and welded (except submerged arc-welded) austenitic and austenitic-ferritic steel tubes for verification of hydraulic leak-tightness
钢管无损检测  第2部分:验证无缝和焊接(埋弧焊除外)奥氏体和铁素奥氏体钢管水压密封性的自动涡流检测
EN 10246-3:1999 Non-destructive testing of steel tubes - Part 3: Automatic eddy current testing of seamless and welded (except submerged arc-welded) steel tubes for the detection of imperfections
钢管无损检测  第3部分:探测无缝和焊接(埋弧焊除外)钢管缺欠的自动涡流检测
EN 10246-4:1999 Non-destructive testing of steel tubes - Part 4: Automatic full peripheral magnetic transducer/flux leakage testing of seamless ferromagnetic steel tubes for the detection of transverse imperfections
钢管无损检测  第4部分:探测无缝铁磁性钢管横向缺欠的自动全周磁传感器(漏磁)检测
EN 10246-5:1999 Non-destructive testing of steel tubes - Part 5: Automatic full peripheral magnetic transducer/flux leakage testing of seamless and welded (except submerged arc welded) ferromagnetic steel tubes for the detection of longitudinal imperfections
钢管无损检测  第5部分:探测无缝和焊接(埋弧焊除外)铁磁性钢管纵向缺欠的自动全周磁传感器(漏磁)检测
EN 10246-6:1999 Non-destructive testing of steel tubes - Part 6: Automatic full peripheral ultrasonic testing of seamless steel tubes for the detection of transverse imperfections
钢管无损检测  第6部分:探测无缝钢管横向缺欠的自动全周超声检测
EN 10246-7:2005 Non-destructive testing of steel tubes - Part 7: Automatic full peripheral ultrasonic testing of seamless and welded (except submerged arc welded) tubes for the detection of longitudinal imperfections
钢管无损检测  第7部分:探测无缝和焊接(埋弧焊除外)钢管纵向缺欠的自动全周超声检测
EN 10246-8:1999 Non-destructive testing of steel tubes - Part 8: Automatic ultrasonic testing of the weld seam of electric welded steel tubes for the detection of longitudinal imperfections
钢管无损检测  第8部分:探测电弧焊钢管焊缝纵向缺欠的自动超声检测
EN 10246-9:2000 Non-destructive testing of steel tubes - Part 9: Automatic ultrasonic testing of the weld seam of submerged arc welded steel tubes for the detection of longitudinal and/or transverse imperfections
钢管无损检测  第9部分:探测埋弧焊钢管焊缝纵向和(或)横向缺欠的自动超声检测
EN 10256:2000 Non-destructive testing of steel tubes - Qualification and competence of level 1 and 2 non-destructive testing personnel
钢管无损检测  1级和2级无损检测人员能力与资格鉴定
yoyojal | 2015-3-5 10:24:45 | 显示全部楼层
EN 10246-8 ,这个标准哪里可以分享啊
fgh222 | 2016-1-29 22:32:47 | 显示全部楼层
看看了
