[分享] ISO/TC 17 Steel,钢
查看4599 | 回复1 | 2013-8-11 14:33:08 | 显示全部楼层 |阅读模式
ISO/TC 17  Steel,钢
ISO 4986:1992
Steel castings -- Magnetic particle inspection
铸钢件  磁粉检测
ISO 4987:1992
Steel castings -- Penetrant inspection
铸钢件  渗透检测
ISO 4992-1:2006
Steel castings -- Ultrasonic examination -- Part 1: Steel castings for general purposes
ISO 4992-2:2006
Steel castings -- Ultrasonic examination -- Part 2: Steel castings for highly stressed components
ISO 4993:1987
Steel castings -- Radiographic inspection
铸钢件  射线照相检测
ISO 5948:1994
Railway rolling stock material -- Ultrasonic acceptance testing
铁路车辆材料  超声验收检测
ISO 6933:1986
Railway rolling stock material -- Magnetic particle acceptance testing
铁路车辆材料  磁粉验收检测
ISO 9302:1994
Seamless and welded (except submerged arc-welded) steel tubes for pressure purposes -- Electromagnetic testing for verification of hydraulic leak-tightness
承压无缝和焊接(埋弧焊除外)钢管  验证水压密封性的电磁检测
ISO 9303:1989
Seamless and welded (except submerged arc-welded) steel tubes for pressure purposes -- Full peripheral ultrasonic testing for the detection of longitudinal imperfections
承压无缝和焊接(埋弧焊除外)钢管  探测纵向缺欠的全周超声检测
ISO 9304:1989
Seamless and welded (except submerged arc-welded) steel tubes for pressure purposes -- Eddy current testing for the detection of imperfections
承压无缝和焊接(埋弧焊除外)钢管  探测缺欠的涡流检测
ISO 9305:1989
Seamless steel tubes for pressure purposes -- Full peripheral ultrasonic testing for the detection of transverse imperfections
承压无缝钢管  探测横向缺欠的全周超声检测
ISO 9402:1989
Seamless and welded (except submerged arc-welded) steel tubes for pressure purposes -- Full peripheral magnetic transducer/flux leakage testing of ferromagnetic steel tubes for the detection of longitudinal imperfections
承压无缝和焊接(埋弧焊除外)钢管  探测铁磁性钢管纵向缺欠的全周磁换能器(漏磁)检测
ISO 9598:1989
Seamless steel tubes for pressure purposes -- Full peripheral magnetic transducer/flux leakage testing of ferromagnetic steel tubes for the detection of transverse imperfections
承压无缝钢管  探测铁磁性钢管横向缺欠的全周磁换能器(漏磁)检测
ISO 9764:1989
Electric resistance and induction welded steel tubes for pressure purposes -- Ultrasonic testing of the weld seam for the detection of longitudinal imperfections
承压电阻焊和感应焊钢管  探测焊缝纵向缺欠的超声检测
ISO 9765:1990
Submerged arc-welded steel tubes for pressure purposes -- Ultrasonic testing of the weld seam for the detection of longitudinal and/or transverse imperfections
承压埋弧焊钢管  探测焊缝纵向和(或)横向缺欠的超声检测
ISO 10124:1994
Seamless and welded (except submerged arc-welded) steel tubes for pressure purposes -- Ultrasonic testing for the detection of laminar imperfections
承压无缝和焊接(埋弧焊除外)钢管  探测分层缺欠的超声检测
ISO 10332:1994
Seamless and welded (except submerged arc-welded) steel tubes for pressure purposes -- Ultrasonic testing for the verification of hydraulic leak-tightness
承压无缝和焊接(埋弧焊除外)钢管  验证水压密封性的超声检测
ISO 10543:1993
Seamless and hot-stretch-reduced welded steel tubes for pressure purposes -- Full peripheral ultrasonic thickness testing
承压无缝和热拉缩径焊钢管  全周超声测厚
ISO 11484:1994
Steel tubes for pressure purposes -- Qualification and certification of non-destructive testing (NDT) personnel
承压钢管  无损检测人员资格鉴定与认证
ISO 11496:1993
Seamless and welded steel tubes for pressure purposes -- Ultrasonic testing of tube ends for the detection of laminar imperfections
承压无缝和焊接钢管  探测管端分层缺欠的超声检测
ISO 11971:2008
Steel and iron castings -- Visual examination of surface quality
铸钢件  表面质量的目视检测
ISO 12094:1994
Welded steel tubes for pressure purposes -- Ultrasonic testing for the detection of laminar imperfections in strips/plates used in the manufacture of welded tubes
承压焊接钢管  探测焊接管用带(板)材中分层缺欠的超声检测
ISO 12095:1994
Seamless and welded steel tubes for pressure purposes -- Liquid penetrant testing
承压无缝和焊接钢管  渗透检测
ISO 12096:1996
Submerged arc-welded steel tubes for pressure purposes -- Radiographic testing of the weld seam for the detection of imperfections
承压埋弧焊钢管  探测焊缝缺欠的射线照相检测
ISO 13663:1995
Welded steel tubes for pressure purposes -- Ultrasonic testing of the area adjacent to the weld seam for the detection of laminar imperfections
承压焊接钢管  探测焊缝附近分层缺欠的超声检测
ISO 13664:1997
Seamless and welded steel tubes for pressure purposes -- Magnetic particle inspection of the tube ends for the detection of laminar imperfections
承压无缝和焊接钢管  探测管端分层缺欠的磁粉检测
ISO 13665:1997
Seamless and welded steel tubes for pressure purposes -- Magnetic particle inspection of the tube body for the detection of surface imperfections
承压无缝和焊接钢管  探测管体表面缺欠的磁粉检测
ISO 17577:2006
Steel -- Ultrasonic testing for steel flat products of thickness equal to or greater than 6 mm
fgh222 | 2016-1-29 22:34:48 | 显示全部楼层
看看了
